Bsod - where is my crash dump?
Ex_Brit
If you're going through hell, keep going
In my test rig on D: I have Vista x64 and was testing some software which caused some BSOD's.
In order for the maker to sort out why it's happening I wanted to send them the crash dump but can I find it? No!!
I have hidden and system files set to viewable and there simply is no crash dump anywhere that I can find on C:Windows or D:Windows, although the BSOD did say it was writing it and got to 100% before I rebooted.
Anyone experienced this "lost crash dump" syndrome?
(I've since had to uninstall the software in order to use that partition, so can't repro this without going to a lot of trouble).
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
zigzag3143
Banned
Ex_brit
the dump should be in D:\windows, but you can search for it *.dmp. the other place it may be hiding is D:\windows\minidump
let me know if you need help
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Ex_Brit
Thanks Ken. It simply is not there or anywhere. Fortunately someone else using that software in their x86 system got the same BSOD and did forward their crash dump so hopefully the maker of the software will get it sorted out. Glad it wasn't just me.
(It's McAfee Beta Labs by the way).
I have it set to give me a kernel dump rather than a small memory dump, that would normally give the full dump right?
Maybe I didn't wait long enough before rebooting. It did say it had saved the dump.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
zigzag3143
Banned
Ex_Brit
Kernel is larger. Problem with kernel is that its the size of your ram plus 1 mb for the dump header so if you have 4 gigs ram the dump is gonna be BIG. It gives a little more info about the problem and anyone with a debugger can analyze it.
Sometimes there is n ot dump. If the crash happens early enough in memory and causes a double fault the computer cant store the dump file.
Should you want to cuase the blue screen on command there is something called driver verifier. it will cuase it to happen so you can get a dump file
Let me know if you need help
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Ex_Brit
That might explain it...I have 12gb of RAM so I'd better set the dump back to its default small size.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
zigzag3143
Banned
Ex_brit
what exactly are you trying to analyze? btw a 12 gig dump would give us a little more info but not much.
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Ex_Brit
I am not trying to analyse anything. McAfee wanted the dump. Anyway, it's moot now as there is no dump.
Thanks for your help.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
lil domii
Seven Guru + GFX
Power User
wow, some rig you have got there ex_brit!
as in performance...
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
Ex_Brit
Thanks. In Win 7 it gives me 7.8 on everything except disk read speed and that is 5.9...probably because I chose the non-RAID route after a few problems wrestling with RAID 0. Although I'm not sure if it also includes in that such things as external USB drives, in which case that would probably drag that score down too.
In Vista everything is 5.9.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
Ex_Brit
OK thanks. My page file settings are automatic.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
archie123
I Tunes hates Me
you wanna uncheck "overwrite existing file" if your collecting crash dumps for someone :)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Ex_Brit
OK, thanks.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
Ex_Brit
Sorry to rehash this, but I'm still mystified as to why I'm not getting dump files. Testing beta products means the makers require dump files to help them redesign the product...in this case McAfee 2010 home security products which consistently BSOD in Vista Ultimate SP2 x64 (but NOT in Windows 7...weird).
I have made sure that each drive has its own paging file and a big one too because my memory is 12gb.
The only comment I've got from McAfee is that Microsoft is to blame and they are working together with them on the problem. That's of no help to me.
Fortunately this on my D: Test drive so doesn't effect my day-to-day work.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
usasma
Old and cranky
There is a long discussion in Windows Internals 5th Edition about the problems that can cause you to not get a crash dump (on pages 1130 and 1150)
Ex_Brit
Well, I'm not about to spend $69.99 to find out what it says.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
Ex_Brit
Oh - thanks foir that. I looked on Technet and couldn't find what I was seeking, obviously I didn't look hard enough.
One problem though, I don't seem to be a member of that and I see no link to Join.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
usasma
Old and cranky
It's an MVP benefit - I got it in an email a while back.
I'd check the MVP member's site - or your Lead.
The program is being done away with in 2010, so get what you can now!
Ex_Brit
I can't find it in any of my emails. I'll ask Sasha my lead. It's probably too technical for me anyway.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
