Solved BSOD (with minidump)
Gamemaster2237
I have been getting this bsod error 0x124 for more than a month now when playing games...:(
I have been doing some tests and found out before the crash mycpu useage goes to 85-100%
Windows problem and soution say --->
You received this message because a hardware device, its driver, or related software has caused a blue screen error. This type of error means the computer has shut down abruptly to protect itself from potential data corruption or loss. In this case, we were unable to detect the specific device or driver that caused the problem.
here is the mini dump file|
  • Mini072709-01.zip
    Hewlett-Packard Comany a6200n
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ 2.60GHz
    Phoenix - AwardBIOS v6.00PG
    2.00 GB RAM
    HP w1907 Wide LCD Monitor
    1400 x 900 x 4294967296 colors
Are you using the latest service pack and security updates?
I had a problem one time (and you dont have a seperate sound card) where if you didnt install this one update from microsoft, upon closing a game, the CPU cycles would be 100% because of sound card holdup.
This could be caused from a program as well, but im not sure because
this is a newer issue than the one i had.
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache
    (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4 Ghz Wireless Keyboard
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
I use windows update for securtity update and i have SP2 if thats wat ur saying
it will be helpful if some one reads my mini dump
  • Mini072709-01.zip
    2.00 GB RAM
Then this issue is for someone else. sorry i can't work with minidumps. takes a while to setup the symbol path for the debugger.
    1920 x 1200
ITs cool:cool:
but i really need someone to read this mini dump
  • Mini072709-01.zip
    2.00 GB RAM
Code:
BUGCHECK_STR:  0x124_AuthenticAMD
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  BF2142.exe
CURRENT_IRQL:  0
STACK_TEXT:
8253af38 8241b9dd 00000124 00000000 84a98028 nt!KeBugCheckEx+0x1e
8253af8c 82509520 84a98028 84ecc3a8 84ecc3a8 hal!HalBugCheckSystem+0xe1
8253afb8 8241b8f1 84ecc3a8 8242efb4 8253aff4 nt!WheaReportHwError+0x1d0
8253afc8 8241bfed 00000003 84ecc3a8 00000000 hal!HalpReportMachineCheck+0x31
8253aff4 8241799f 80151000 00000000 00000000 hal!HalpMcaExceptionHandler+0x115
8253aff4 00000000 80151000 00000000 00000000 hal!HalpMcaExceptionHandlerWrapper+0x77
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  0x124_AuthenticAMD__UNKNOWN
Followup: MachineOwner
this a sample of your .dmp file.
It seems that while playing game you are experiencing the issue. This thread will help u :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    DELL
    Dell
    100 mbps(office lan)
Code:
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
Sorry no dice maybe this will clear things up a bit
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2
BCCode: 124
BCP1: 00000000
BCP2: 878BC020
BCP3: B6602000
BCP4: 00000135
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
.2.0.768.3
Locale ID: 1033
ths was for the latest crash 0x000000124
  • Mini072709-01.zip
    2.00 GB RAM
Code:
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
BCCode: 124
BCP1: 00000000
BCP2: 878BC020
BCP3: B6602000
BCP4: 00000135
Service Pack: 2_0
Product: 768_1
.2.0.768.3
Locale ID: 1033
So that was what i was looking at as well....
None the less, from the BSOD, it's hardware issue from playing BattleField 2142.
You probably hardcore game sometimes on it too correct? Overclocked GPU or CPU maybe?
All drivers latest and Directx runtimes are up to date?
Just shootin out some idea's. correct me if any of these are wrong.
    1920 x 1200
Code:
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
BCCode: 124
BCP1: 00000000
BCP2: 878BC020
BCP3: B6602000
BCP4: 00000135
Service Pack: 2_0
Product: 768_1
.2.0.768.3
Locale ID: 1033
Well...
I do have some out of date drivers (8 drivers) maybe that could be causing the problems
    2.00 GB RAM
BCCode: 124
BCP1: 00000000
BCP2: 878BC020
BCP3: B6602000
BCP4: 00000135
Service Pack: 2_0
Product: 768_1
.2.0.768.3
Locale ID: 1033
Well...
Just be safe, first of all, update your video drivers if thats one, then soundcard (if you have one and need an update for that as well) and then 3rd motherboard drivers if necessary.
Also, check if BF2142 has any newer patches available. I have heard this game has given others lots of grief as well however, its a good game to play.
    1920 x 1200
Well...
I update everthing but two thing my
NVIDIA nForce Serial ATA Controller and Realtek High Definition Audio 6.0.1.5789
cant seem to find upadtes for these
    2.00 GB RAM
Thnxs for all your help guys!
As you alll know i have been hhave bsod error ox124 when playing games (bf2142) but i have solved my problem. It was vista service pack 2 update dont know y it caused this error but i am very glad it is gone i have given rep pionts to everyone that post on the bsod threads thnxs everybody :D:D:D
btw if you play bf2142 my tag is gamemaster2237
see you on the battlefield :cool:
    2.00 GB RAM
Re: Thnxs for all your help guys!
Cool man.
The Realtek HD audio update and the Nvidia Serial ATA update are not needed updates because there was a more recent driver after them, so it came up on mine as well.
Nice to see that it was so simple.
    1920 x 1200
