BSOD woes
twocold
1
Im getting this error during installation, towards the end of the process
IRQL NOT LESS OR EQUAL
0x00000007
running:
ASUS M2N SLI Deluxe, Nforce 570 chipset
WD 500gig hard drive 16MB cache, single partition
LiteON DVDRW
Gforce 8800GT 512MB GDDR3
Creative Audigy XFI extreme gamer (which ive uninstalled as a step to try to eliminate this error)
AMD Athlon 64x2
4gig DDR2
The installation goes well until after it reboots and tries to complete. It will reboot and run for a few minutes before the BSOD. The only thing i have'nt tried is to use something like VLITE to inject the drivers from ASUS. I'm reluctant to do that since the chipset driver from ASUS for vista x64 is a beta. I have also tried to disable any unnecessary hardware in the BIOS to help to narrow the search down a bit.
HELP!!!!!!!!!!:cry: I want my computer back!!!!!!!!!!!
MrNeeds
PC Geek
1,823
Location
Lymm, Cheshire, UK
0x00000007
running:
LiteON DVDRW
AMD Athlon 64x2
4gig DDR2
this is straight from microsoft with your error code,
Error Message:
STOP: 0x00000007 (parameter, parameter, parameter, parameter) INVALID_SOFTWARE_INTERRUPT
Explanation:
This is a Windows 2000 Executive character-mode STOP message. It indicates a level not within the software range.
User Action:
If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
