Solved Can I install Vista on portable hard drive?
In a word, the answer is no.
The ability to run a live Windows system on a USB device was a new feature in Windows 8 Enterprise called Windows To Go.
It is possible, with some effort, to create a Windows To Go workspace with any edition of Windows 8.
Other Windows versions (Vista, 7) are not portable because of how drivers are handled.
In the past, Windows had always considered USB devices as "input devices" and not suitable for use as a system drive.
I also own an older Mac (Intel) computer. Interestingly, I can run the Mac from a system loaded on an external drive, either USB or Firewire, no problems at all, in fact several systems on multiple partitions. Speed is a little pokey but acceptable.
Why not just get a new HDD?
Maybe.
Microsoft never supported installing Vista on an external drive. It may be possible but it won't be easy. This is more of a stunt than a practical option.
I agree, No not really a viable option
That is not the way to fix your problem.
Get a copy of Macrium Reflect and make an image of your system and store it on another drive, it can be your usb drive
Burn a Macrium boot disc.
Replace the failing drive
Boot the computer with the Macrium boot disc
Reload the image you made and you have your computer back as it was
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Thanks for the replies
I guess I won't be doing that then haha, my Vista installation is old (it came with the laptop when I bought it new) and has never been reinstalled since then but I have a Vista ISO from another thread here so I might just attempt that before looking for a new internal hard drive.
