You should upgrade or use an
alternative browser .
Can lack of power cause blue screen crashes
How likely is it that regular video driver blue screen crashes are caused be an insufficient power supply?
Thanks
AMD Athlon 64 X2 4800
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Sapphire HD4850 Toxic Edition
Samsung SM2493HW
500GB Seagate, 160GB Seagate
Corsair HX520W
Antec P182 Gunmetal Grey
that sound like memory more than power supply, have you tested you memory?
intel core 2 quad Q9450
gigabyte EP45-DQ6
8gb Gskill PC6400
Visiontek Radeon 4870x2 2GB
X-FI fatality FPS 7.1
Viewsonic VG2230wm
1680X1050
VelociRaptor WD1500HLFS 150GB 10000 RPM,
WD CAVIAR black 750GB
Antec TruePower New TP-750 watt
Cooler Master HAF932
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
comcast 16mb\second
Yes i have done 2 memory diagnostic checks and both have indicated no problems.
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
what exactly is happening for you to say the video card driver? starting a game?
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
Playing a game, watching tv. Occasionally watch videos in media center. Even on one occasion playing an online flash game.
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
have you tried updating the driver?
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
Yes several times. I have also tried them from other sources and tried older versions. The problem exists. I have been told that the problem could be caused by the fact that my power supply is not powerful enough. I just want to know if it possible that an insufficient power supply would cause blue screen crashes because if not i can eliminate that as a cause.
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
in my experience when a power supply goes the drives and so forth do not work right and towards the end you have hard time just booting. i should know, it just happened to me
it died over 1 month period of time, but i never had blue screens during that time
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
AMD Athlon 64 X2 4800+
Asrock AliveSata2-glan M/B
2gb DDR2 4200 Kingston Ram
500gb Seagate SATA HDD
150 Seagate IDE HDD
Lite-on DVD DL RW
Hauppauge Nova T500 tv card
ATI HD 2600 XT (GDDR4 version)
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
what size power supply? also, what version of windows and what chipset driver are you using?
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
Its a 400W. I think its just a generic brand. It came with my colors-it case. I am using vista home premium x64 and ati catalyst version 7.10.
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
you didn't install your chipset driver?
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
at 400 watt that is a little small for that system, i would get bigger one
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
spend a little money if you can afford it and get nice power supply
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
Sorry i dont know what my chipset driver is? How do i find it out? I did think they 400W was a bit small but could understand why it would cause blue screens
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
well with what you have in your system there is not enough juice to go around, so like for instance if you select to use the tv card and it goes to draw power that is not there it crashes. as far the chipset driver look at the asrock site for the latest on it
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
i would make sure you have things backed up in case the power supply does go
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
The asrock website lists all the individual drivers for sound, lan etc and i have got the latest version of all them. Here's the link:
ASRock Motherboard - Product - ALiveSATA2-GLAN - Download
The thing i don't understand is that my secondary hard drive has xp on it so i can boot from that and i dont have any problems with blue screens in xp. just vista. Does vista use more power than xp?
ASUS M2N-SLI Deluxe
4GB OCZ PC-6400
Samsung SM2493HW
Corsair HX520W
no, that is telling me it might be driver related to 64 bit vista
gigabyte EP45-DQ6
8gb Gskill PC6400
Viewsonic VG2230wm
1680X1050
comcast 16mb\second
