Can not open secondary email account using Outlook 7
Cnotedog
When I try to open my wife's email using Outlook 7 we get a message that says cannot open our default email folder: File access is denied. You do not have the permission to access the file c:/users/myname/appData/microsoft/outlook/outlook.pst. Comcast is my internet provider and the mail account is setup through them. Please Help!
Lottiemansion
First do you have separate log-on's?
It sounds as thought the file is not there or you are trying to import it?
Have you used Outlook to set up the account in your log-on or are you importing the file?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Cnotedog
Yes, we have separate logins using Vista. We are trying to log into her Outlook account. We get that message when we click on Outlook under her profile.
Lottiemansion
OK,
How did the account file get created?
Are there any email messages in Outlook which are not on the server?
i.e Saved to a local folder in outlook which is not listed on the server.
If not: -
Try deleting her account in Outlook & start again.
    40 Meg
Cnotedog
I can't get beyond the error message box to do anything in outlook when I click ok it just closes outlook. Also, I have another computer and I can access her outlook account just fine on that one. I am running windows xp on that one. The problem just started when I moved and had to set the computers back up. Never had this problem before I moved.
Lottiemansion
    40 Meg
