anonprivate
Hello.
I recently moved and connected my pc via wi-fi, under Linux, to the new network without any difficulty.
But when trying to connect my laptop under Vista 32 bit, via wi-fi, all I can achieve is Local Access.
Any advice appreciated.
I give some data that might help you help me:
Laptop is: Toshiba Satellite, L350-20G
Network Adapters are:
Atheros: AR5007EG. and
Realtek: RT8102E
Evidently, both are up to date and working.
IPconfig/all:
Windows IP Configuration
Host Name . . . . . . . . . . . . : OD-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-24-D2-2F-7D-12
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.7(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8102E Family PCI-E Fast Ethern
et NIC (NDIS 6.0)
Physical Address. . . . . . . . . : 00-1E-33-A6-A6-08
DHCP Enabled. . . . . . . . . . . : Yes
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
C:\Windows\system32>
Realtek: RT8102E
IPconfig/all:
et NIC (NDIS 6.0)
- Dell E520
- Pentium D
- 1 GB
