Can you run all 32 bit application in a 64 bit system running vista?
kakkalo
i am kinda newbie to the 64 bit world and i am trying to buy a new laptop which is preloaded with 64bit version of windows vista home premium. but my question is can i run all the apps that i use now on the new machine.
like say i want to use firefox. so can i just go to firefox.com and download and run it. will it run properly? or i need some kind of special version of the software.
so can any of you help me with it before i buy the ladtop. thank you :)
lordbob75
Lord of Bobs
Vista Pro
That is a very good question. Hopefully my answer is just as good: yes. Everything should run just fine. I use firefox myself on a 64 bit and it works. All your programs should work just fine. Some may not work too well, and some have 64 bit forms, but 98% should work normally.
Thanks be to the computer gods for backwards compatibility!
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
Dzomlija
Resistance is Futile
LordBob75 answered your question nicely. The only thing he neglected to mention is that on x64 systems, you cannot run 16-Bit programs, which includes older 32-Bit applications that still use 16-Bit installers.
Other than that, I concur 100% with LordBob75's answer: Most, if not all, 32-Bit programs should run without issues on Vista x64.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
kakkalo
thank you both of you guys. @Dzomlija is there any way to find out if a software uses 16bit installer. like some of my daily uses program are firefox, ms office, vlc player, photoshop,notepad ++, dreamweaver, avg anti virus (free edition) and of course firefox.
does any of those software fave any competebility issue or is there any thing eles that i should keep in mind.. thank you again :)
lordbob75
Lord of Bobs
Vista Pro
I use all of those in my 64 bit system, never had a problem.
@dzomlija: that's why it was 98% not 100%.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Dzomlija
Not really, except for the older apps. And I'm talking about those from pre-XP days, up to those of about 2002 - 2003. Other than that, if you're using all recently released applications, they will all probably use the Windows Installer services, which never supported 16-bit anyway.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
johngalt
Antidisestablishmentarianist
There is a caveat - any 32bit application that tried to install a driver that is not 64bit OS compatible will not work (such as some obscure VPN clients, etc).
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Everlong
To xor or not to xor
The only thing he neglected to mention is that on x64 systems, you cannot run 16-Bit programs, which includes older 32-Bit applications that still use 16-Bit installers..
I actually got the original Fallout to install on Vista 64, which uses a 16-bit installer. Had to run it in Windows 95 compatibility mode, but it still installed and the game ran fine no problem.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Dzomlija
I doubt that installer is 16-bit - Vista x64 just does not support 16 bit apps, no matter what compatibility options you choose.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Everlong
Well the forum I read, which helped me to get it working, are saying it is a 16 bit installer and it can only be run in Win 95 mode.
    ASUS Xonar DX
    100Mbps
Dzomlija
Then you're one of the lucky ones.
I've just done a test with some really old software (Office 97, if you must know), and I got the "This is not a valid Win32 Application" error, no matter what compatibility settings I used.
It doesn't really matter, does it? Since in the rare case when I do have a program that uses a 16-Bit installer, I run in on XP inside Virtual PC 2007.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Everlong
Well I might be wrong anyway, and it might just be a 32 bit app as I read in the readme file that there was problems with running Fallout on Window NT systems, so that forum might just have been wrong, as at first when I read it was sceptical myself to it actually being 16 bit.
    ASUS Xonar DX
    100Mbps
