cannot access control panel
rebwriter
When try to get into the control panel, i get a message that says Windows Explorer has stopped working, then one that says Windows will restart your computer and it does. Keeps up this cycle. I have Vista 32bit, have run spyware and virus scans. HELP.
johngalt
Antidisestablishmentarianist
Hi, rebwriter, and welcome to the forums.
Run SFC /Scannow from a CMD prompt.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
acadamis2000
IT Consultant
Vista Pro
You can also try instead of launching the Control Panel from the start menu
start > run > type control > press enter
See if that makes any difference on the launch. Might not make a difference just trying to throw some new things out there to try.
    Intel Core 2 Duo e8400
    EVGA 680i SLI
    4GB Buffalo Firestix
    EVGA 8800 GT - 2x XFX 8600gt
    Seagate 300gb 7200 rpm
johngalt
Good point academis - it could very well be just a start menu problem....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
