Cannot access programs and features.
xbeethx
2
i've had this problem for a while, and can't seem to find any fix for it. i've looked through these forums for similar problems, and tried the given solutions but nothing seems to work.
i can open control panel fine, then when i double click programs and features, the loading icon appears briefly and disappears immediately.
i've downloaded several registry cleaning tools that haven't helped and tried to enable in the registry editor, which also didn't work.
can anybody help?
thanks.
richc46
Staff member
20,105
Location
Fairfield County, CT
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
Hello xbeethx, welcome to Vista Forums!
Using "several registry cleaning tools" has probably only made matters worse, that's the last thing one should do as most of them are nothing but snake oil and do nothing but delete the wrong 'things' from the registry and continued use will completely disable the PC.
Do you have a Vista install disk? If you do and the excellent suggestion from Richard above doesn't help, even after several runs, have a look at the tutorial at the link below.
Be sure to post back to keep us informed.
How To Perform a Repair Installation For Vista
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
markaz
Power User
186
Location
Peoria, Arizona
I agree with BFK. And FYI, what Rich is describing.....click on the Start Button and in the search box enter appwiz.cpl. If it appears in the results, what happens when you click on it? If it doesn't appear in the results, then a repair install will be needed.
    HP Pavilion s3700y (PC)
    AMD Athlon 64 X2 Dual Core 5000+
    Pegatron Acacia
    3GB Micron Technology (PC2-6400)
    NVIDEA GeForce 8400GS
    Realtek High Def Audio
    Compaq WF1907
    1360x768
    Western Digital 320GB
    Slimline
    A little fan
    Logitech M305
    eMachines Enhanced Multimedia
    2703 kbps
xbeethx
2
i had a feeling they wouldn't help, but i was clutching at straws :(
i ran the sfc/scannow, it says windows resource protection has discovered corrupt files but was unable to fix some of them.
when i type appwiz.cpl, it does appear in the results, but when i click or press enter, a new windows explorer window opens and immediately closes...
i guess it's not really that big a deal, i have an external hard drive i could transfer all my files to and re-format my laptop. i just wanted to know if there was a fix and, if possible, find out what caused the problem in the first place, so i can avoid it in the future.
thanks for the help :)
markaz
Power User
186
Location
Peoria, Arizona
You definitely have corrupted file(s), but don't know that you have to format the drive. As BFK posted, you can repair install and you won't lose data/pic/etc files (even though a backup of what's important is crucial). Brink's explanation is EXCELLENT and walks you through it step-by-step. Take it from me, it works well.
Good luck on whatever you decide to do.
    Pegatron Acacia
    Compaq WF1907
    1360x768
    Slimline
    A little fan
    Logitech M305
    2703 kbps
