Cannot connect to internet EVEN WITH wireless drivers...
DAMASTER7
So I go to the HP driver download website, and I download all of the MODEM, GRAPHICS, CHIPSETS, ETHERNETS, WIRELESS, INTERNET CONNECTION drivers and whenever i download them, put them onto a FD, transfer them to the computer I am having the problem with, install them, and restart the computer, it doesn't make it so the Wifi will notice my wifi in my house.. Help please?!?!
    HP DV9700
    2 GB
    Nvidia Piece Of Crap
    idek
    1440 x 900
DAMASTER7
You guys gave me a TIP, not a helpful tip... This windows repair tool requires money, and internet access, which is what it said, AND, I already know my problem, but I just cant get the drivers to install properly.
    HP DV9700
    2 GB
    idek
    1440 x 900
davidr100
if you are using free wi-fi (over the air) and not a paid wi-fi service, (ISP), then maybe you might want to check to see if your wifi button is clicked on. there should be a wifi button on one of your top keys of your keyboard which allows you to turn wifi on or off. There usually is a light associated with it or if there is no button, then there should be a slide to turn wifi on or off on the side of the laptop. In either case, look for the wifi switch or button or toggle, etc.. that is built in on to your computer (laptop) and see if that is the problem. Hope this helps.
ilikefree
What post asked you to download Windows Repair Tool please?
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Cammygirl192
Cammy White FTW
You did check to see if they supported your version of Vista, correct?
Most things don't support it completely anymore.
    Packard Bell imedia s3210
    AMD Athlon(tm) 7450 Dual Core Processor (2.40GHz)
    2.00GB
    NVIDIA GeForce 8200
ilikefree
    LENOVO 64734VM
    15 inch
    External Speakers
Vistaar
Has anyone noticed that the original post was 13 months ago?
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
ilikefree
    LENOVO 64734VM
    15 inch
    External Speakers
