Cannot connect to internet using Ethernet Cable but can connect with USB cable
mamas2crazy
Last week i decided to move my computers (2). Internet was working fine before i did this. After I moved them I havent been able to connect except for a usb cable. Both computers are using the Windows Vista home premium 32 bit. Before all of this happened I had 2 computers and an Xbox 360 all connected. I have tried everything I can think of and none of it worked. I have charter cable internet and they were able to get on the internet fine using the ethernet cable. when i go to ipconfig/all it gives me a 169.254.216.245 IP address. I have read several places where people have been having problems with this but all the suggestions for them nothing worked for me! Please help
Joan Archer
Cross Stitch Queen
Do you connect via a modem or a router. Did you try the release/renew options when you were in ipconfig ?
If you use a router check it to see if it's still giving out IP's automatically.
