Solved Cannot remove a program in Control Panel (Intellitype pro)
I had Intellitype pro 7.1 installed awhile back. I thought I had it successfully uninstalled, however I noticed the other day that it was still listed in Programs and Features in Control Panel. When I click on it there are no options for 'Modify' or 'Uninstall'. I did a search for Intellitype in my C drive and found only a couple of empty folders which I then deleted. This did not solve my problem though... I found a couple of Intellitype items in my regedit but I do not want to be messing around with my registry without knowing the consequences. How do I remove this program from my Control Panel and is it safe to delete these items in the registry?
(computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Intellitype Pro, computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Intellipoint Intellitype Pro Bluetooth, computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Intellitype Pro Auto Update)
    Dell Studio Laptop
    Intel Core 2 Duo 2.66GHz
    ATI Mobility Radeon HD 4570
    1920x1080
richc46
Staff member
Fairfield County, CT
Posts
20,105
MilesAhead
Eclectician
Posts
2,442
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Brink
Staff member
mvp
Oklahoma, USA
Posts
32,218
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Thanks for the very fast responses!
I have solved my issue. I forgot that CCleaner had a tool for uninstalling programs. It has removed it successfully. Problem solved.
    Dell Studio Laptop
    1920x1080
richc46
Staff member
Posts
20,105
Thanks for reporting, you have helped others with your courtesy. You will always be welcome at the Forum, either to benefit from our expetise and knowledge or to share yours. You may, also, be interested in the information contained in our extensive tut. library.
http://www.vistax64.com/tutorials/139940-tutorial-index.html?filter[11]=General Tips
