Canon 350D driver problem.
Blakey
I have recently bought a new base unit with Vista Home Premium 64bit installed. I have loaded all the software that came with my Canon 350D camera but Vista says it need to install new divers for a Canon Digital camera when I connect it via USB. It can not find any drivers on the install disc and recommends I install drivers for a "EOS KISS_N REBEL_XT 350D". I have checked the Canon website for the drivers and found no reference to the recommended drivers? I have found update for the software that came with the camera which I have applied but it still says it's found new hardware when I connect the camera.
The current versions of software installed are:
Digital Photo Professional ver 3.0.2.6
EOS Utility ver 2.0.2.6
ZoomBrowser EX 5.8.0.74
I have done a google search which brought up several sites none of which appear to work.
Can anyone point me in the right direction to get this working.:confused:
Hi Blakey,
I do not know if you have this one or not, but I found this at Canon:
http://software.canon-europe.com/products/0010192.asp
1. Canon Camera USB WIA Driver for Windows Vista (6.0.0)
Compatibility:
Operating system(s): Windows Vista 32bit
Language(s): English
It says it is not compatible with the x64 Vista or x64 XP though, only 32 bit versions.
Sorry,
    Logitech MX Master 4
Yep Canon Doesnt have 64-bit driver support at all :(
One thing you can do is get a Compact Flash card reader and use that to transfer your images while this driver thing gets sorted out on Vista X64 :)
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
Hi Guy's,
Firstly thanks for the response. I have downloaded the Canon Camera USB WIA Driver for Windows Vista (6.0.0) and rightly so the system will not allow it to be installed.
The camera does use Compact Flash cards so I will have to transfer them via a reader as suggested. Hopefully Canon will realise that support for 64bit is the way to go and produce a driver in the near future.
Once again thanks for your assistance.
Regards
Paul.
Paul,
Your welcome. At least there is a workaround for now.
Ive been using my Canon 400d on my 64bit vista installation flawlessly for months, i plug camera straight into usb port, Is the 350 THAT different from the 400 ???
From what the Original poster says it looks like the 350 is different from your camera.But i still cant beleive Canon doesnt have proper drivers for Vista X64.
    Intel
    Nvidia 9650M GT
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
Would you not be better using a card reader ? transferring from camera to computer drains the camera battery very quickly, at least it does on my canon 300d.
Card readers are cheap and easy to install. I'm surprised there's not one on your new base unit, I thought they were pretty much standard add-on these days
I had the same problem in vista.but this problem is solvable by change a setting on your camera.for solve the problem change your camera's Communication setting(last option in camera menu) from Print/PTP to PC Connection.when you change this setting you'll see it work like before on XP.I think it works on Vista X64.
In fact, mine 350d was on PC Connection and i changed this setting to PRINT/PTP. It worked like a charm after that on my Vista x64 Ultimate.
Hi Everyone
I know some time has passed, but I just used this fix today on my 350D / Vista 64x. I would never have thought to change the Comm mode in a hundred years so thanks very much...:)
I have recently "upgraded" to Seven 64 bits, and maybe this tip also runs with Seven -x64 !
How did you manage to install ZoomBrower EX or DigitalPhotoProfessional to work on the RAW files ??
Thanks
