Canon pixma MP 780
loisns
I updated my driver for this printer in order to use it with a new VISTA computer. In doing this, my XP laptop, can no longer use this printer. Is there a simple solution to this?
MadBull
Updating drivers usually doesn't affect the hardware itself. Its strange that it simply stopped working because you installed vista drivers on another computer. My Pixma was simply a plug-and-play from my vista desktop to my XP laptop.
Can you provide more detail? Does the computer detect the printer but it simply doesn't print? Or is the printer undetected completely? Maybe you could try uninstalling then installing new drivers for it.
Canon Australia - PIXMA MP780
    3.6 Ghz AMD Phenom II X3 720 BE
    Gigabyte MA790X-UDP4
    4GB OCZ DDR2 800Mhz
    Asus EAH4850 512MB
    Samsung SyncMaster 2253BW
    C: 320GB Seagate SATA
    D: 720GB Seagate SATA
loisns
I did as you advised, and uninstalled and reinstalled the software for the Canon Pixma mp780. The laptop with XP recognizes and finds the printer, but when I ask it to print, it makes the attempt and comes back with the message "failed to print".
I have used this printer on the laptop for a couple years now, and it just pulled this stunt after I purchased a new desktop with VISTA and had to find a new driver for it.
I have Vista Home Premium 64bit.
rajinisback
Vista Pro
Hi loisns
Welcome to the forums.
I am going to assume this printer hooks up to the laptop via USB cable. What happens if you plug the printer into a different USB port? I would assume Windows XP would see it then reinstall the printer for you use.
Raj
loisns
Raj,
My laptop is on the first floor of the house, the MP 780 is upstairs with a direct usb to the Vista desktop. The laptop has never had a direct connection to the printer.
