Solved Can't Access NVIDIA Control Panel
Kotuku
Power User
All of a sudden (probably started 10+ days ago) I can't access the NVIDIA Control panel, I get an instant error message, as per attached. I am running 175.16 driver and I can't install newest driver as I need to access the NVIDIA Control panel so I can set up dual monitors.
I can't even run Driver Sweeper, it leaves 3 files behind and I don't think it does an uninstall.
HELP!
    Intel Core2 Extreme Quad Core
    XFX MB-N790-IUL9 NFORCE 790 U
    4 Gb (2x2) Gskill DD3 1600
    XFX 9800GX2 Black Ed. 1Gb DD3
    2x WD Raptor 150 Gb SATA 10000rpm in Raid0 plus 500 Gb Seagate 7200rpm SATA2
Brink
Staff member
mvp
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Kotuku
Power User
Thanks Shawn, as I have NVIDIA MoBo etc, my Prog & Features shows 5 entries
NVIDIA Drivers
NVIDIA Forceware Network Access Manager
NVIDIA Performance
NVIDIA System Monitor
NVIDIA System Update
The first two show nothing in the SIZE column. Now it would seem the first is what I need to uninstall, yet I don't want to remove all my MoBo drivers etc. It is not specificall there anything that says Video Drivers
I think I may have a bum installation of the 175.16 drivers? Maybe I should first re-install that.
Can installation of the Video drivers be done in Safe Mode to make sure nothing interferes, or is it better in normal?
Thanks
Frenchy
Brink
Staff member
mvp
Hi Frenchy,
It would be the NVIDIA Drivers entry. It can be uninstalled in Safe Mode if you like, but it should not matter.
    Lumia 1520 phone
Kotuku
Power User
OK, When I Uninstalled the Vista Drivers, a screen popped up to give me the option of what driver I wanted uninstalled. I did that and installed 175.19 and that still would not let the NVIDIA Control Panel start. Uninstalled that and back to 175.16 but still will not allow control panel to run, with an APPCRASH error. I am stuck!
chevell
Banned
When you uninstall the drivers, get there though the "control panel home"/choose uninstall a program, choose nvidia drivers/click "remove only the following"/nvidia display driver, this will also take you into safe mode at which point you would also use driver sweeper..."while still in safe mode" choose/nvidia display/choose clean/driver sweeper will now remove the rest of the display drivers entries, then restart and install new driver.
Once you restart right click on desk top and choose nvidia control panel/choose advanced settings/let it adjust resolution if needed. It should be there now, if not you have other problems.
    E6750
    EVGA 780i
    GSkill PC6400 @ 1000MHZ 4 4 4 12
    280-GTX
    2X250 GB WD
Kotuku
Power User
Thanks for that, that was 'slightly better', but no solution! The trick was I needed to run the Driver Sweeper as an Administrator other wise it didn't do its thing. All files removed and I installed 175.19 and a clean install but again the NVIDIA Control Panel didn't start and failed with an APPCRASH. I uninstalled 175.19 cleanly and installed 175.16, again same problem and the error code is for the APPCRASH is
Problem signature:
Problem Event Name: APPCRASH
Application Name: nvCplUI.exe
Application Version: 1.5.2400.10
Application Timestamp: 481bfde7
Fault Module Name: NMI.dll
Fault Module Version: 2.2.0.6781
Fault Module Timestamp: 48105f75
Exception Code: c0000005
Exception Offset: 0000000000028cd2
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 5129
Additional Information 1: 6ee2
Additional Information 2: 9811633d2846e0fec22dbfdde637c6b1
Additional Information 3: 2201
Additional Information 4: 7913f394dae755f6ac53a46114693bcc
If anyone can interpret that, I will be eternally grateful. I have Rollback Rx on board, so I take a snapshot before any of this and then roll back when it fails.
Kotuku
Power User
OK, I bit the bullet and rolled back my system to 29 Aug. That solved the problem. Unfortunately I have no idea what caused the problem as only normal Windows Vista updates and a quick install and uninstall a few days later of Google Chrome. I have re-installed the Vista Updates and the problem has not re-occurred.
This problem went away (I have my Control Panel back) plus a few other niggles, like not able to create a restore point. I had installed Rollback Rx earlier in August, so this REALLY saved my bacon! I have to say this program is a God send when doing Video driver installs that don't work and a few seconds later able to revert the system back. However, this ain't a plug for that program, just reporting the problem solved.
