Can't burn a DVD, Message: Insert a blank disk
mwade
Hello,
I have a new Vista computer and when I go to burn a CD (for example how Vista wants you to make an initial back up of your system, and it asks you to insert a CD/DVD to make a copy) and when I put in a brand new writable DVD in to the DVD player it keeps telling me that I need to put in a new disk. It will not let me burn it. I have tried it with many different disks, all of which are writeable and DVD with the DVD device.
Message: Insert a blank disk.
I have also tried this on another vista system and get the same results.
Any thoughts? Do the DVD's need to be formatted? The DVD's are new and I thought that they only sold formatted DVD's.
Thanks
dustinface
Hello,
No, the dvd's do not need to be formatted, they are blank and ready to be written on when purchased.
Also are you using a quality brand, or is it of questionable quality?
    Me/Myself
    AMD Athlonx2 7850 Kuma
    Gigabyte MA770-UD3
    2gb PQI Turbo DDR2 800
    Saphire (ATI) 3870
    Onboard HD audio
    Hanns-G 19" WS LCD
    WD 250gb SATA
    Apevia 500w
    Antec 300
    120mm Fan x 4; 140mm Fan x 1; ARCTIC COOLING Freezer 64 Pro
    Razer Deathadder
    Microsoft Media Edition
    >12mbit down; >2mbit up
zigzag3143
Banned
Hello,
Thanks
Are you using DVD +RW or DVD -RW? what does your dvd player support?
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
zigzag3143
Banned
M
Two things. you should go into the device manager (type device manager in search) and look for your dvd drive and make sure it is installed and working properly. If it has a yellow triangle on it, or if it is not there then you need to install a driver. If it is there are you right click it go to properties and it should say this device is working properly.
Check the front of the dvd drive see if it says dvd +, dvd -, or dvd +, -. If its not listed check the owners manual.
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
mwade
Thanks all for the help. I see that there is a lot of questions about whether the DVD disk and player are DVD -R or DVD +R. I read about the diferences, but it doesn't tell me if they are interchangeable. Meaning, I should be able to use both -R and +R right? Or does it depend on my player. One of the two DVD 's that are not cooperating just say DVD rewritable.
zigzag3143
Banned
MW
Does the drive work with the vista dvd, and others not of the new batch? If so its the new ones, if not maybe a driver
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
JimJoe
If the dvds wont work in any machine, it is the dvds.
edit:
to make sure, use one of the DVDs towards the bottom of the stack in the other computer. If it doesn't work there, then it wont likely work in the one you originally posted about.
You might have gotten a bad batch of DVDs.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
MilesAhead
Eclectician
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
