You should upgrade or use an
alternative browser .
Solved Can't close sidebar
When I right click on the sidebar icon in lower right corner to "Close" sidebar only the "Open" option is available to me. I want to use the gadgets on my desktop and not the sidebar. Supposedly I am able to do this by detaching the gadgets and then "Close" the sidebar. No matter how many times I right click on the icon the "Close" option will not come up. I have tried opening webpages and then moving all the sidebar stuff to the front using the "Bring Gadgets to Front" option and then trying to close the sidebar from there but that doesn't work as well. Am I missing something here??? please help!!!
Hello yrdxjjj, and welcome to Vista Forums.
You should be able to right click on an empty area in the Sidebar itself to have the
Close Sidebar option available.
You might also consider to uncheck the
Start Sidebar when Windows starts box in the Sidebar properties to not have the Side bar always run at startup.
http://www.vistax64.com/tutorials/81260-windows-sidebar-startup.html
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thanks Shawn! That worked perfectly
You're most welcome.
Operating System
Operating System
