You should upgrade or use an
alternative browser .
Solved Can't create shortcuts via Right-Click
About a week ago I noticed that I could no longer right-click and create shortcuts. When I click on New > Shortcut, nothing happens, and I can't figure out why...
I'm running Vista Home Premium.
I would really appreciate it if someone could help me, its extremely aggravating.
Thanks
HP Pavilion dv6729ca Notebook
4gb
Razer Deathadder
Intel Dual Core 3 GHz
3 GB DDR 2 667 Mhz
ATI X1550 256 MB
Samsung 19"
80 GB IDE Samsung.
iBall
iBall
2mbps
it also sounds like your registry is messed up so that it's not offering you that choice anymore..
maybe there's an easy way u can edit the registry entry for the context menus inside windows explorer...i'm sure there must be.
i haven't done it, but i would imagine you'd be using REGEDIT for that purpose.
built myself & slaved over every last friggin wire ;)
dual AMD opteron 2384 (8 cores)
tyan THUNDER s2932-e
8 banks of kingston 4 GB PC6400 800 Mhz (32 GB total)
NVIDIA GeForce 8600 GT (X2) SLI'd
creative sounblaster X-fi platinum
NEC multisync 2490WUXi 24" LCD (X2) & SAMSUNG 46" flat screen LCD TV
1920X1200 , 1920X1200 , 1920X1080
2 hitatchi SAS 15000 rpm
6 western digital caviar black 500 GB sata II 7200 rpm
550w Silencer Turbocool
lian-li pc-75B
14 fans & lots of copper :)
microsoft natural ergonomic 4000
microsoft wireless optical
optonline boost ;)
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thanks for the helpful suggestions everyone. Unfortunately, nothing seems to be fixing it
. I turned off system restore, so it looks like I have a fresh installation of vista in my very near future.
4gb
Razer Deathadder
Mike, I have updated the .reg file there to include more default registry settings for this. You might see if it may work now for you.
Operating System
Operating System
Thank you, but that one doesn't seem to work either.
4gb
Razer Deathadder
Compaq Presario C700
Intel Core 2 Duo 1.67 GHz
Intel GM965
2.5 GB (2 GB Transcend + 512MB Hyundai)
Intel Intergrated 965 Express Graphics
Conexant High Definition
Compaq
160 GB Compaq
Compaq
Alps Pointing Device Touchpad
2 Mbps Download, 512 Kbps Upload
Integrated Web-Camera
(P.S. Have another custom-built PC with Win7 x64)
THANK YOU SO MUCH! that shortcut reg fixed worked perfectly!!! just wanted to thank the author for that...it fixed mine - I first exported my registry just to make sure...applied the patch with the new reg entries he mentioned and viola IMMEDIATELY after applying the patch I could begin making shortcuts again via the desktop!!!
a huge thanks
You're most welcome Kjanine, and welcome to Vista Forums.
I hope that Hitman has it sorted by now as well.
Operating System
Operating System
THANK YOU so much. I'm a computer wiz I FINALLY fixed sfc /scannow on my mom's Windows Vista 64bit and I'm slowly fixing it.
I have restarted the computer at least 5 times and scanned it using SFC It has SO MANY problems.
The right click new short cut wasn't working, I DO NOT like messing with the registry
But thanks to you IT WORKS
thank you so much
