cant delete files from maxtor external drive
mulmike
first post for me here , need help solving a problem . just recently upgraded my system , dell precision 690 work station 64 bit . was working on xp 64 pro now on vista ultimate . works great with a coupl of quirkes , one which is very annoying , i have a maxtor external hard drive 1TB which i cant seem to delete files from , keep getting the error message 0x80070571 disk structure is corrupted and unreadable . dosnt seem to be as i can copy files to computer HD and edit to my hearts content . i would like to be able to delte many unwanted files from the maxtor and think this is a permissions problem . working thru my computor and going into the maxtor HD properties i seem to have all the permissions i need but when i then go into the maxtor HD and highlight a folder and check out the security permissions in properties the options are grayed out and unchangable .
thanking you in anticipation of a positive response
mulmike
    dell precision 690 workstation
    intel(R) Xeon(R) CPU [email protected] 2.66GHx
    8.00GB
    ATI fireGL V7200
    photon 20vision II
    1600x1200
    seagate ST3300555SS SCSI
    maxtor one touch IEEE 1394 SBP2
    logictech
    logictech
    broadband 7168/384 (kbps)
CyberZeus
Welcome to Vista Forums!
I think it's not a permission problem, the error talks about corruption.
I suggest you to backup the data on your esternal hard drive and format it in "Disc management".
CyberZeus
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    [email protected]@75MHz
    1 x Seagate 120GB SATA (OS installation)
    1 x Seagate 200GB SATA
    2 x Seagate 320GB SATA (Hardware RAID 0)
    1 x Seagate 250GB IDE (in external USB box)
    1 x TrekStor 750GB USB
    650W
    Logitech Cordless Optical
    Logitech Cordless Desktop EX 100
    8192 kbps / 640 kbps
sassofalco
What bad, bad,habit?
mulmike
CyberZeus
G'Day mulmike and bon giorno CyberZeus,
The problem of Error message 0x80070571 first appeared when I tried to do a scheduled back-up to the Maxtor HD, and showed like this;
I then tried delete a Folder from the M:\ drive, and got the following Error message;
With that, I thought that I would try and work within the M:\ drive by creating a new Folder, then merging all the unwanted Files and Folders into it, and then deleting that. No go. In trying to create a new Folder, up came;
I've just spent days trying to find a fix for this error......without success. Today, I resolved the issue by downloading all the Folders and Files that I wanted to keep to other Drives, [Hard Drives and Flash Drives], and to be certain, then Formatted the Maxtor HD [M; \ drive], including all retained Backup Files, TWICE!!
A new system backup went through like a breeze.......but my fingers are still crossed!!
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
CyberZeus
Hope it'll work!
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
sassofalco
Hope it'll work!
......that's why the crossed fingers, and lighted joss-sticks. I ran chkdsk on the Drive, but it came up with nothing. From what I've read, there seems to be some issue with Windows Registry/Maxtor HD, but nobody seems to have found the bug.
