Can't install Creative X-Fi Audio driver
Everlong
To xor or not to xor
I've got a SoundBlaster X-Fi Audio sound card, and put it in to my new PC. PC boots up fine, but doesn't detect the sound card. Tried it in another PC and it gets picked up fine.
When I try installing the drivers, it just says no product can be found on the PC. In Device Manager, all it shows is the onboard sound, and when I disable onboard audio in BIOS, it just doesn't show anything in device manager.
Only thing I can think of is it has something to do with the .inf file for the soundcard...
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
stormy13
PCI or PCI-E? In either case if you haven't (and can), try it in another slot.
BTW if you really want a X-Fi you might want to consider returning that one and getting at least the Xtreme Gamer, as th only thing even remotely X-Fi like about the Xtreme Audio is its name,
X-Fi Xtreme Audio
The entry-level model of the X-Fi series, the Sound Blaster X-Fi Xtreme Audio, does not actually have the EMU20K1 chip but is a re-branded Audigy SE, using the same family of chips (CA0106-WBTLF), and even the same drivers.[8] Thus, not only is all of the X-Fi–related processing performed in software, but it also lacks basic hardware acceleration just like the SB Live! 24-bit, the Audigy SE and other budget Soundblaster models. The X-Fi Xtreme Audio does not use the same drivers as the rest of the X-Fi family, some games do not recognize it as being "X-Fi capable hardware", and the device's hardware profile resembles that of older Live! and Audigy cards.
Furthermore, users have reported that it slows down some applications and games, and that rear sound in games (all) is muffled and of profoundly low quality.[15][16][17] Thus, even if the card is marketed as part of the X-Fi line, it does not belong to it technically, just like the Audigy SE doesn't technically belong to the Sound Blaster Audigy series. The card is not marketed as supporting the "X-Fi Gaming Mode" (but is still marketed as "X-Fi"), and there are no official implicit or explicit statements regarding its having hardware acceleration or not.
Sound Blaster X-Fi - Wikipedia, the free encyclopedia
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Everlong
It was a PCI. Tried it in both PCI slots and still nothing.
Tried everything, like manually locating the .inf file from the driver and still wasn't finding it.
Might just do what you said and try an Xtreme Gamer one.
    ASUS Xonar DX
    100Mbps
stormy13
Good idea. Looking at your specs it looks like you got the card mainly for gaming, and I can pretty much guarantee that you would be disappointed with that card. If it is in your budget I would look even higher and go for the Auzentech Prelude X-Fi; better overall than the Creative cards (not sure about the new Titanium series) due to better components on the card (DAC's, opamps (which are changeable), etc).
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
sygnus21
Here to learn
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Everlong
Drivers aren't the problem. I have the latest ones for it, it's that the PC doesn't even recognise it being there, like device manager shows no audio device attached to the PC with it.
I looked at the Fatal1ty though, and it's a bit too much, so I'll most likely get the Xtreme Gamer when I can.
    ASUS Xonar DX
    100Mbps
