Solved Can't resize Taskbar
We had a power cut here and my Computer , burglar alarm and central heating boiler all had problems this morning. I have just one problem left which I can't get right.
The task bar managed to get itself to the side of my screen , so I dragged it back to the bottom where it changed to a very large size, about 1" deep. I tried to use the mouse to get the arrow to drag it down and resize it, but it will not go back to it's narrow size. Any ideas please ?
    Intel Pentium Dual core 2.2GHz
    RAM 4 GB
    250 GB C: drive
    Maxtor one touch 111 external HD 250GB
    Logitech Wireless
    Logitech Wireless
    Broadband (don't know speed!)
richc46
Welcome
Its rather simple if you know how. Good luck
Resize the taskbar
Thanks for the link but that is what I have already tried to do ! I have just had another go and instead of using the double headed arrow at the top of the taskbar, I clicked on the dots at the side of the Start Orb and dragged it to the right and then it went back to it's original , narrow size.
    RAM 4 GB
    250 GB C: drive
    Logitech Wireless
    Logitech Wireless
richc46
Glad that you got it sorted out. Thanks for using the Vista Forums.
