Ccleaner question
Fred22
I've been using CCleaner on my win10 laptop, but just added it to my Vista desktop, which is shared by my wife and myself. Do I need to run this app on both mine and hers, or does running it on mine (administrator) clean the entire computer?
    Dell Inspiron Laptop
    AMD A8
    Generic
townsbg
~~тσωηsвg~~
I did an analysis on my Vista VM from my admin account and with the exception of my firefox instance (which is shared by both accounts) it only showed system files or files for that user so it looks like you will have to run from both accounts. I do not recommend that you run the registry cleaner.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
Fred22
Thanks. Is the same true for the free version of MBAM?
    AMD A8
    Generic
townsbg
~~тσωηsвg~~
I don't know for sure but it should have access to everything if run from an admin account.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    Poweredge T140
    1440 x 900
    1 TB & 360 GB
richc46
Welcome
CCleaner DOES clean only one account at a time. Malwarebytes will clean all accounts in paid version only. Townsbg is correct when suggesting that you do not use a registry cleaner. It is not needed and may cause more problems than it solves.
