CD/DVD Drive Not Working
chrisavfc
Hi, was hoping somebody may be able to help me.
I was running football manager 2008 last night and I quite the game, 15 minutes later my laptop overheated and turned off (it gets extremely hot regularly.)
Now the disc drive won't work.
It shows up in the Device Manager and it says it has no problems and its running fine.
I put any disc in and the lights come on, and you hear it working away, but nothing is shown on the My Computer Screen and nothing pops up.
I've no idea what is wrong with it, and have limited knowledge about this tbh.
Any questions I'll try my best to answer them, any screenshots and that just ask.
Cheers guys
Hi Chris
You can try the following ZIP file.
After downloading and unpacking,
click the CD-DVD fix.vbs file,
and restart your computer.
I hope this helps
    Acer Aspire 5738G-644G32MN
    Intel Core 2 Duo - clockspeed 2000 MHz
    Acer JV50
    RAM 4 GB - SO-DIMM DDR3
    NVIDIA GeForce - G105M - 512 MB
    1366 x 768 Pixels
    Hitachi HTS543232L9A300 320 GB - Type SATA - Speed 5400 rpm
    Logitech Wireless Mouse M505
    Azerty
    Currently 14.5 MB/Sec which means 1.8 MB/Sec effective
try going into device manager, uninstall the drive, reboot, let the computer re-detect the drive and install the "drivers". see if it works then
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
