CD-RW Write protected?
Vista_32bit
Vista_x64 :P
I am trying to format a cd that I bought (memorex) vista says it cannot be formatted because of its write protection. Unfortunately this is my only blank cd left so I can't use a new one. Is there a way of forcing a format? Or removing the write protection? thanks
    *Modified*Dell Inspiron 531s
    AMD Athlon 64 X2 2.3GHz
    Dell RY206 0RY206
    4GB Corsair XMS2 PC2-6400 DDR2
    XFX GeForce GTS 250
    Creative X-Fi XtremeGamer 5.1 Surround Sound
    Dell SE198WFP 19-inch Widescreen Flat-panel LCD
    Seagate Barracuda 320GB 7200RPM
    LOGISYS 575W SLI Ready ATX12V
    Cooler Master CM 690
    2 120mm, 4 vents optional fans
    Microsoft Wireless Notebook Mouse 3000
    Dell Stock
    20 MB/s Down...2 MB/s Up
rive0108
insert it, and right click the Properties of the optical drive, and see if it is write protected.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
Vista_32bit
Vista_x64 :P
It doesn't really say. It only says it is if I try to format.
    Dell RY206 0RY206
    XFX GeForce GTS 250
    Dell Stock
rive0108
Why are you trying to format the disk? have you tried just erasing it? is it a cd-r or cd -rw disk?
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
Vista_32bit
Vista_x64 :P
It has songs on it, the songs can not be deleted. As I said when I try to format it says it is write protected, so there is no way for me to add or delete date from it.
    Dell RY206 0RY206
    XFX GeForce GTS 250
    Dell Stock
rive0108
The disk may be corrupted, and may be "unfixable". I suggest you go borrow or buy a new pack of cd's/dvd's
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
Vista_32bit
Vista_x64 :P
Well, I just noticed. Any CD I burn music to from iTunes is write protected. Is there a way in iTunes to make it not protected?
    Dell RY206 0RY206
    XFX GeForce GTS 250
    Dell Stock
rive0108
First, are you using CD R disks or CD RW disks? [only CD RW disks (DVD RW/BD RE) disks can be erased)
the following can only be burned to ONCE, and cannot be erased/formated, etc.:
Note- most external players cannot read Re-Writable CD disks
CD R/DVD R/BD R
iTunes DRM only protects the songs- it does not prevent erasing. If you have a "Write Protected Media" error it either is due to a non-rewritable disk/corrupted disk (aborting either the format/burn/erase process will cause disk corruption), or User Corrruption in Vista (i.e., "Access denied")
I suggest you run the built in Administrator Account, and see if you can then erase the CD RW disk. If you can, then you can try taking Ownership, or create a New Admin User Account, As this means your User Account has been corrupted poss through use of a reg cleaner/malware/User error.
http://www.vistax64.com/tutorials/67567-administrator-account.html
Two, Before you burn to the disks in Vista it "autoformats" to either:
LIVE FILE SYSTEM (default- allows files to be added/erased like a flash drive)
or MASTERED (prevents individual files from being deleted afterwords)
What type of disk are you using and what are you formating to before burning?
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
rive0108
This is an example of a CD-RW disk that has been corrupted:
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
rive0108
Erasing a Disk with Vista:
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
