I saw a older thread on this topic, I tried to run the fix it program but I am getting error code 0x80092003, I hope someone who had the same problem can tell me the manual fix
Run a system file check by going to the start search box and typing cmd
Hold shift and ctrl and press enter
That should open an administrator command prompt.
Type sfc /scannow into that box.
If errors are found run the command again (up to 3 times)
Restart your computer after each time to allow it to repair files that may be in use.
Post back with results.
Conexant 20561 SmartAudio HD
15 inch
1x 180GB Intel 530 series SSD
1 x 120GB Hitachi 5400rmp
Medium for New Zealand
Only ever used a laptop.
Also use USB Freeview TV Card
Lenovo Docking Station
External Speakers
Other bits a pieces as needed
Ran and restarted 3 times I get the message that corrupt files are found but could not repair all the message in my device manager is
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
editing the registry got everything working again Thanks for everyones help, the sad part is I ordered a new computer last week, but for some reason it's not due to arrive until the 22nd
15 inch
External Speakers
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
