Chameleon Clock 5.1
Domsy
Hi everyone,
I am quite a big fan of Chameleon Clock. I believe it's a brilliant enhancement to the normal clock that comes with Windows. I have been using it with XP Pro (x86) all the time.
However, since moving to Vista Ultimate (x64), Chameleon Clock no longer appears on the taskbar. It's running fine, it still does all the functions (like alarms, reminders, clock chimes, etc), and I can still access it by hovering over the normal clock. But it just does not show the clock itself. I've just got the normal Vista one, which really quite defeats the point of having Chameleon Clock in the first place.
I've put up with it because the most important functions still work, but I do not understand why it will not appear. I have done nothing different to XP, and I have tried loads of different settings.
The website for Chameleon Clock says it's Vista compatible, yet it does not seem to work for me. Maybe perhaps it's because of 64-bit? I do not know...
Has anyone else got Chameleon Clock to show on Vista Ultimate x64? I'd really appreciate any help.
Thank you
    Intel Core 2 Quad Q6600
    Asus P5K-Deluxe
    4GB DDR2 800MHz
    XFX Nvidia Geforce 8800GT 512MB Alpha Dog XXX Edition
    A lot
    Corsair HX620W
    Gigabyte 3D Aurora
    Quiet air
    Logitech MX Revolution
    Logitech G15
    Up to 8Mbps
Domsy
So, is no one able to provide me any information on this?
Can anyone tell me if they get Chameleon Clock 5.1 to be visible on Vista x64? If anyone can prove or disprove this, I can take the problem to the developers.
    Asus P5K-Deluxe
    4GB DDR2 800MHz
    A lot
    Corsair HX620W
    Gigabyte 3D Aurora
    Quiet air
    Logitech G15
    Up to 8Mbps
paleo
I just went to a computer with Vista Home Premium 64bit. Chameleon Clock worked great on my old Windows XP system but now the clock doesn't show up in the tray; just the normal Windows clock. All the other Chameleon Clock functions work but the clock is not there. Anyone also have this problem and have cured it?
JorgeX
It also dosnt run on XP64 - looks like it dosnt work with any X64-systems. on my testsystems (Vista64 and XP64) I dont even have the other functions except of the calender when hovering over the time - how and where did get the other functions?
paleo
You can get to the other functions by right clicking on the calendar. Then click "Advanced Tooltip Options". Everything works except the tray clock. I've emailed the Chameleon Clock people about the problem but they have not answered back.
garry35
not on vista i an on windows 10 x64, but the clock never appears same as above. when i try vista compatibilty mode by right clicking properties of chameleon clock, the desktop vanishes and no programs will come to the front forcing me to go into safe mode to restore to normal
townsbg
~~тσωηsвg~~
My educated guess is that the developers never made it compatible with anything past Vista. Anything that has to do with changing the way that windows looks (such as themes) only apply to the Windows version that they are designed for. I would put a custom clock as being in that category since it is replacing the default clock.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
