Check what update I have?
jason123
I have Windows Vista 64 bit installed with Service Pack 2 and I want to update it to the latest 2017 updates. I was trying to install the Windows Vista Update Repository from greenhillmaniac on MSFN but I don't know how to check what updates were installed and what I have to install. Winver only shows the windows build not the security updates that were installed.
Is there a way to see what security updates I have installed and not just the build number?
If you want to know I am on build 6002 service pack 2
    Acer Aspire 7720
    Core 2 duo
    2gb ram
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Yeah I noticed that is how I check the updates I installed. When I go to the passed installed updates I only see the other updates I installed thought the .msu
I wanted to fully update my system to the last 2017 updates and I ran the commands to install the .cab files and I get the installing updates thing when shutting down the computer but It never shows up in the passed installed updates.
    Acer Aspire 7720
    Core 2 duo
    2gb ram
You might also also check from programs and features. I'm not sure how that cab install method works.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
It is not in the program and features. The only thing that is there is the screen drivers that I installed.
    Acer Aspire 7720
    Core 2 duo
    2gb ram
I found where the installed updates are. Turns out I had to click on installed updates instead of view update history. I am also using the updates from Josh Davison's video on YouTube since its easier to install the updates with those .bat files.
    Acer Aspire 7720
    Core 2 duo
    2gb ram
Sorry but you c;lick on installed updates from programs and features. If you've ever had issues with Windows update and had to reset your profile the history will be gone.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
I never reset my profile history. To check the updates I went to view update history then installed updates and that worked. It is a new install.
    Acer Aspire 7720
    Core 2 duo
    2gb ram
