Clean C Drive & reinstall Vista from Recovery Drive D / Disk
GasSpam
Due to various rement programs and fear of viruses, I would like to wipe clean the "C" drive and restore the system to its original out-of-box settings using either the "D" partition or the system produced recovery disks.
You can use either. Make sure to save any thing of value to you on cds/dvds. Then just follow on screen prompts and that's it.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
akn10red
and what if someone installs windows 7 to that "cleaned" drive C and after sometime wants to restore that windows vista from drive D???
richc46
Usually, if Seven is installed to a Hard Drive with Vista, the recovery partition is lost. Most members just format the entire drive and install using the clean install method.
ilikefree
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Bare Foot Kid
R.I.P. August 13th 2014
Hello akn10red, welcome to Vista Forums!
If the original partition structure has not been changed it may work, who manufactured the PC, what make is it so we can post the instructions to give it a try, you've got nothing to lose.
Have a look here
In future only ask a question one time as it gets confusing to keep up with them.
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
