Clean then Defrag OR Defrag then Clean
mitchellb
Removed by request
74
I was wondering what should be done first.
I use CCleaner and recently downloaded Defraggler (but have not used it because of this question).
Should I run CCleaner and THEN run Defraggler?
OR
Run Defraggler and THEN run CCleaner?
I've thought about just using CCleaner only and no defragging.
ilikefree
2,877
Location
New Zealand
Clean first and if you are going to use Defraggler you will need to go to Task Schedular and click on defrag.properties and uncheck the enable box as you don't want 2 defraggers running. It is turned on by default
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
richc46
Staff member
20,105
Location
Fairfield County, CT
You want to limit the defrags, so you will not wear out the hard drive. Here are some additional pointers.
To maintain your computer
10 Tips on How to Properly Maintain Your Computer
Steps that I did not notice on the guide include:
Running a scan disc before doing a defrag
Using Microsoft Security Essentials and Malwarebytes.
Making System Restore points, at least once a week
Makaing a system Image once a month (varies by user)
Not relying on your A/V common sense, should prevail. You know of many sites can cause a problem.
Do not use any reg cleaning or optimizing software.
Download and use Ccleaner about once every two months. Untick any registry entries.
http://www.piriform.com/
If you follow these instructions, you will be trouble free for a long time to come.
Be sure to back up your hard drive about once a month (varies by user) and to keeep system restore points up to date.
Optimize Windows 7
ilikefree
2,877
Location
New Zealand
I know, I have disabled/turned off Windows Defrag program long ago. Thanks.
Just checking as a lot of people forget that part.;)
    LENOVO 64734VM
    15 inch
    External Speakers
MilesAhead
Eclectician
2,442
I set CCleaner to empty the recycle bin. I clean just before defrag, and also right before doing MalwareBytes scans. It's a pain if MalwareBytes finds something it doesn't like in the recycle bin. You can close MalwareBytes, empty the recycle bin, then run the scan again but it's just a nuisance if you know for sure what the stuff in the recycle bin is(for example if you do scripting programming those are often false flagged as a malware.)
This way I only have to remember to run CCleaner immediately before these other tasks.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
mitchellb
Removed by request
74
So I ran the Defraggler program. When it first analyzed my hard drive it said 12% fragmentation. I click to defrag. Once it was done. Just for curiousity, I had it re-analyze my hard drive and then it said it there was 28% fragmentation. I did not continue with another defrag.
But why would fragmentation go up?
I probably should be asking the programs website and not this forum.
richc46
Staff member
20,105
Location
#8
This could happen when going from one defrag software to another. They analzye differently. If that is the situation, I would defrag once more, it should go to zero. Then only when needed.
derekimo
Staff member
784
Location
Shasta County
#9
I seem to remember something like this happening to me as well, is it system volume information that's not defragging?
I'm using Auslogics now and I don't get that anymore.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
mitchellb
Removed by request
74
#11
I'm sorry but I wouldn't know if it is system volume information.
Care to elaborate?
richc46
Staff member
20,105
Location
#12
Even if my analysis is wrong, and I dont think that it is, you need a defrag, 28% is too high. After you are done stay with Defraggler is that is what you used.
ilikefree
2,877
Location
New Zealand
#13
Quote from Derekimo
Thanks cost nothing so I just switched from Defraggler to Auslogics
    LENOVO 64734VM
    15 inch
    External Speakers
derekimo
Staff member
784
Location
Shasta County
#14
Care to elaborate?
Sure, after you click analyze and it tells you how much is fragmented, click the view files button, and it will list them for you.
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
richc46
Staff member
20,105
Location
#15
If it makes any difference I use auslogics, too and am very satisfied. It seems to defrag a lot faster than the others.
MilesAhead
Eclectician
2,442
#16
Puran is pretty comparable to Auslogics. Also when you do analyze or actually defrag it produces an html table with the fragmented files, folders, MFTs etc.
Sometimes if I have a fresh image backup I'll turn off System Restore to delete all the shadow copies, do the defrag with all optimizations on in Puran, then turn System Restore back on and make a restore point. That method dumps all the backup copies of files and other bloat you can be collecting. I image often so it's not that risky a procedure. Also cleaning off all the crud first tends to make for smaller restore points.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
ilikefree
2,877
Location
New Zealand
#17
That's an excellent idea. I just remove them with the tools in properties but it always leaves the last one. Does turning it off remove that last one as well?
    LENOVO 64734VM
    15 inch
    External Speakers
mitchellb
Removed by request
74
#18
Care to elaborate?
Ahhh I see, I viewed the files after a 2nd attempt to defrag (as suggested by rich) and the top 2 fragmented files show system volume information.
Fragmentation is still at 28%.
Should I be concerned and download Auslogics and run a 3rd attempt to defrag my hard drive.
I have provided pictures.
richc46
Staff member
20,105
Location
#19
System Volume Information, basically are system restore points. If defragged SR will be lost. They are, therefore, now protected from defrag by most software.
You are ok. Just enjoy, now.
