Compatible Video Cards
clebouef
I have an integrated ATI Radeon HD3200 Graphics and i'm interested in getting a video card to put in. Does it have to be a ATI brand or would any brand work? The system is a Gateway DX4200-09. Any comments would be appreciated. Also I tried putting in a GeForce 9600 GT but after a while the screen freezes while gaming and I have to restart the whole computer.
    Gateway DX4200-09
    AMD Phenom 9150e Quad Core Processor 1.80GHz
    Realtek High Definition
    22"
Lottiemansion
That card should be good enough as a basic upgrade, that is if you have upgraded the the PSU too. 300W is not nearly enought, you neeed 450W minimum otherwise you will get problems.
Have you upgraded the PSU?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
clebouef
I have not upgraded the power supply. But I did notice when I took out the GeForce card that two of the capasitors must have blown as there are split at the top of them. Would the low power supply have caused this?
    Gateway DX4200-09
    22"
Patonb
Honestly a 9600 only needs about 350W, but I suspect heat is the issue. Check your temps using hwmonitor: CPUID - System & hardware benchmark, monitoring, reporting
My entire system maxed out runs 520W give or take. So its iffy if 300W will work.
EDIT
Split caps bad, but no a low psu won't cause it. You seem to have a crAp card.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
clebouef
Thanks for the info, I downloaded the hwmonitor program. I check it out and post what the findings are.
    Gateway DX4200-09
    22"
nostaw5
"POW" Ur dead
Power User
Take it from me. If you have a gpu with heatsink there might be problems. They are nto a major threat but if they do get too hot as they often do while gaming then get a gpu with a fan. But that might need you to have a higher power supply.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
