Solved Compooter won't go to Sleep :(
I've only just noticed... Since my fresh install of Vista x64, it won't go to sleep anymore. I've tried the Fn shortcut, and clicking Sleep from the Start Menu.
When I try to put it to sleep, the screen fades to black (as usual) then after a while, it pops back on to my logon/unlock screen (I have it set to require a password after resuming). It's as though the computer goes to sleep for no time at all, then wakes up almost instantly.
It might be something to do with the one missing driver that I can't seem to get hold of (Toshiba don't do x64 for my computer :(), the "Firmware Linkage Driver" or something.
Any ideas, anyone?
    Intel Core 2 Duo @ 2GHz
    4GB DDR2 @ 667Mhz
    nVidia GeForce Go 7600
    1x 160GB 7200rpm 2.5" SATA
Is Hibernation enabled?
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Logitech G15 V1
    Razer Copperhead Tempest Blue
    100.0 Mbps
Hibernation is disabled, but it was disbled on my old system, too. Hibernation is different from Sleep mode.
When I enter into sleep mode, the only trace of if in the Event Viewer is the following entry in the 'System' view.
Event ID 59, "The system is entering away mode".
    4GB DDR2 @ 667Mhz
Update:
After running
Code:
powercfg -DEVICEQUERY wake_armed
it shows that I have no devices that wake the computer.
Running a
Code:
powercfg -lastwake
says that my computer has been woken up 0 times. Therefore, it is not actually reaching the Sleep state.
    4GB DDR2 @ 667Mhz
Another update, pretty much narrows the problem down:
Code:
The following sleep states are available on this system:
  Standby ( S3 ) Hibernate Hybrid Sleep
The following sleep states are not available on this system:
Standby (S1)
 The system firmware does not support this standby state.
Standby (S2)
    4GB DDR2 @ 667Mhz
OK it's fixed!
I feel such a dip. It was under Advanced Power Settings. In the Multimedia section, I had it set up to prevent sleeping when sharing media! With this set to "Allow Sleep", everything sleeps fine.
    4GB DDR2 @ 667Mhz
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks, but I had just forgotten that I'd changed that setting in my Power Options. I also have a missing driver, so I was slightly worried that it was that causing the problem.
The Tutorials section is pretty good, though - spent a bit of time in their yesterday :P
    4GB DDR2 @ 667Mhz
