computer will not start
nibayred
when i turn on my computer the microsoft corporatio line keeps running for hours,what can i do,i tried everything i know,nothing works
richc46
If you create a recovery DVD, you may be able to boot to recovery options
Create Recovery DVD.
Hard Disc Controller must be set to IDE in BIOS and Bios must be set to boot from the CD http://www.vistax64.com/tutorials/205005-boot-priority-change.html
The Vista recovery disk is used to boot Vista when it won't boot - to run Startup Repair, System Restore, access a Command Line, Recover using a Vista Backup Image, etc.
http://www.vistax64.com/tutorials/194765-system-recovery-options.html. Choose an option tht will not cause you to lose your stuff.
If Vista will not start now, boot the Recovery CD to run Startup Repair which automates System Restore as well as numerous other tests including System File Checker which can repair system files which are not corrupted beyond repair.
If Vista still will not start, try booting into Safe Mode to run sfc /scannow to repair System files.
Special Thanks Given to Seven Forums.
Below is a bulletin distributed by MS to explain the start up procedure when Windows will not boot.
  • Startup Repair. Startup Repair is a Windows recovery tool that can fix certain problems, such as missing or damaged system files, that might prevent Windows from starting. Startup Repair is located on the System Recovery Options menu, which is on the Windows Vista installation disc. If your computer has preinstalled recovery options, it might also be stored on your computer's hard disk. For more information, see Startup Repair: frequently asked questions and What are the system recovery options in Windows Vista? If your computer does not include Startup Repair, your computer manufacturer might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
  • Change restart settings in safe mode. If your computer is stuck in a loop where Windows fails, attempts to restart, and then fails again repeatedly, restart your computer in safe mode and select the Disable automatic restart on system failure checkbox. For more information, see Advanced startup options (including safe mode).
  • Reinstall. If no other options have solved the problem, and you are sure that your computer's hardware is functioning normally, you might need to reinstall Windows. A custom (clean) installation of Windows will permanently delete all of the files on your computer and reinstall Windows, so only use this option if all other recovery options have been unsuccessful. After the installation, you will need to reinstall your programs and restore your files from backup copies. For more information, see Installing and reinstalling Windows**.
richc46
This Refers to Windows 7 --Use Vista Above.
Create Recovery DVD
The Windows 7 recovery disk is used to boot Seven when it won't boot - to run Startup Repair, System Restore, access a Command Line, Recover using a Vista Backup Image, etc.
If Windows will not start now, boot the Recovery CD to run Startup Repair which automates System Restore as well as numerous other tests including System File Checker which can repair system files which are not corrupted beyond repair.
If Windows still will not start, try booting into Safe Mode to run sfc /scannow to repair System files.
Below is a bulletin distributed by MS to explain the start up procedure when Windows will not boot. Startup Repair
Problems starting up a PC can be tricky to fix, since Windows hasn’t had a chance to load its arsenal of troubleshooting tools. Some people simply give up and reinstall Windows.
Startup Repair is designed to prevent a time-consuming reinstallation by diagnosing and repairing problems that prevent Windows from booting. Introduced in Windows Vista, Startup Repair is even easier to use because Windows 7 now installs it on your hard drive for you.
The Startup Repair tool in Windows 7 can help fix problems that prevent Windows from booting up.
Get help
Patonb
Seeing as we have no idea on your knowledge, could you let us in on what you did....
It seems, to me, like a driver issue... try booting in safe mode, and then do a system restore.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
babeskiii
theres this message on my laptop after putting my password which is correct, it says profile cannot be loaded..what can i do? i cant restore it because there's no Start> even i click on the flying window icon its not working...helpppp
richc46
babeskiii
thanks for the reply, but i don't have administrator's account and I can't access the start button to restore the program even if I click on the flying window icon it's not working....
niemiro
Banned
Hello!
You may have answered these already, but I cannot find your answers exactly. Can you log onto any account on the computer, in any way?
Do you have any installation disks?
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
babeskiii
I've been searching for ways to fix this myself, following all the instruction given on "how to fix article" I cannot log on to my laptop, what I'm using now is my other computer, I dont have installation disks, i have here recovery disk i don't know if this disks are the one you're talking about, I'm not an IT person so dont know how to do things the IT way...when I start the laptop i can't get through, after writing my password that phrase will pop up and I can't right click on them to follow some ways to fix it, cant also find the start button and even the icon it's not working, im so pissed and i want to throw that laptop now...jokes! thanks
richc46
Please start a new thread. In the event that the OP returns there will be total confusion if we are trying to answer another's questions.
We will try to help you.
