Computer wont always go into sleep mode
penfan
Banned
every so often I'll leave my computer on for several hours and come back to it and notice that the screen has turned off but it hasnt gone into sleep mode. this doesnt always happen there are time when my computer will sleep when its suppose to but I just cant figure out why it doesnt always do it. I have my screen saver to come on after 10 minutes the screen to shut off after 30 and its set to go into sleep mode in an hour but like last night when I went to sleep with my computer on and woke up hours later only the screen was off. does anyone know the cause of this?
zigzag3143
Banned
Penfan
We could help you a lot more if you would fill in your system spec (lower left corner) so that we know what kind of hardware you have. also 32 or 64bit?
thanks
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
lemur
I wonder if there is some application that is actively running to prevent sleep mode?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Brink
Staff member
mvp
Hello Penfan,
You might check through all of the items listed in this tutorial below to see if it may help to see if something it waking up your computer. A usual cause is the "Allow to wake computer" setting checked in the Network adapter's "Power Management" properties in Device Manager (Control Panel).
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
