Solved Computer Won't Stay Asleep (in sleep mode)
Jeff Yuhas
When I put my Vista Home Premium computer to sleep, it unexectedly wakes up 15-20 minutes later for no reason. I have made sure that on all my devices including the network adapter (except the mouse) that the "allow this device to wake the computer" is unchecked. I have also tried removing Sidebar gadgets to see if one of those was the culprit. I also thought maybe it could be Windows Live Messenger but I set it to not start with Windows and the computer still popped out of sleep mode. I am running (Counter Spy's new) Viper program for anti-virus and anti-spyware and NetNanny 5.6 for as a parental content filter. Any ideas or suggestions would be appreciated.
Thanks!
Jeff
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Jeff Yuhas
Shawn, thanks for the suggestion. I have tried most of the items on this tutorial list before, but not the powercfg command. I ran that command and found two items: my mouse and my High Definition Audio Controller. I have Realtek High Definition Audio which was listed under Sound, Video, and Game Controllers. I right-clicked on the High Definition Audio item and selected properties and there is no Power Management Tab. However, under the Details tab and the Property Box, I selected Power Data and received the following results:
PDCAP_D0_SUPPORTED
PDCAP_D3_SUPPORTED
PDCAP_WAKE_FROM_D3_SUPPORTED
Power State Mappings:
S0 -> D0
S1 -> D3
S2 -> unspecified
S3 -> D3
S4 -> D3
Can you offer any advice on these settings?
Brink
Staff member
mvp
Jeff,
I would not worry about those settings for the HD Audio.
Check in Option Two in the tutorial above to make sure that the Multimedia settings is also set to Allow the computer to sleep.
When the computer wakes up next time, type powercfg -lastwake in a command prompt to see if it can give you any helpful information on what woke up your computer last.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Jeff Yuhas
Thanks again Shawn. I checked my Multimedia settings and it is set to Allow the computer to sleep. So, I put the computer to sleep, it woke up in about 15 minutes, so I tried the powercfg -lastwake command.
Here is the info I got back:
Wake History Count -1
Wake History {0}
Wake Source Count -1
Wake Source {0}
Timer: Fixed Feature
Timer Expired <RTC>
Could this mean there is a timer set to come out of sleep mode? Thoughts?
Jeff
Brink
Staff member
mvp
Jeff,
That would be my assumption too, but I could not tell you from what though. :confused:
Just as a test to eliminate this possibility, unplug your network conenction and put the computer to sleep to see if it wakes up afterwards.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Jeff Yuhas
Shawn, I alos tried and check the BIOS settings, I re-started my computer and went into setup, Power, and the only realted item was Wake On Lan -S4 - Disabled. I will test unplugging the network connection and let you know the results.
Jeff Yuhas
I unplugged my network connection, and put the computer into sleep mode. yet it came awake after about 10 minutes or so.
Any other ideas or suggestions would be appreciated. I just feel at this point that I have tried all the known tiops and advice.
Thanks!
Jeff
johngalt
Antidisestablishmentarianist
You have to have a service that is waking the computer up, or a task that is waking the computer up.
Check your Task Scheduler for any running teaks, and see if any of those tasks are set to wake the computer up.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Jeff Yuhas
Thank you for the suggestion John. I went into Task Scheduler and reviewed all the tasks under the Task Scheduler Library to see if any had the condition set to wake the computer to run that task. I found one: It is called TMM in the list and the description is: Microsoft Transient Multi-Monitor Manager. And it is currently running on my computer. Any ideas or knowledge about this task and if ok to disable the wake condition to run the task?
Thanks much.
Jeff
johngalt
That is basically used to poll your Video card for the number of monitors it is using - it is supposed to be more for laptops than anything, but a lot of people have had problems with it resetting s manually changed settings when using multiple monitors.
If I were you. I'd export the task as it is, and then change that setting and see if it works or not. That might be your whole problem.
It might be mine too :P
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Jeff Yuhas
Thanks for the explanation John. Based on what you said, it appears that it would not be necessary or critical for this task to wake the computer to perform it's function. I think there is a setting in task scheduler to allow a task to perform as soon as possible after waking.
Jeff Yuhas
I would like to share for all readers' benefit that I found the culprit to my Windows Vista computer sleep problem!! I had been running a trial version Iolo's System Mechanic 8 product. My trial just expired and so I un-installed it. Guess what? My sleep problem went away! Even though the System Mechanic product apparently isn't a product that starts and loads with Windows, I discovered two services with the Iolo label so one of those must have been doing something in the background that affected my computer not staying in sleep mode. Too bad because I liked the System Mechanic product. I contacted tech support at Iolo and will post the results of their response.
Thanks Shawn and John for all your help!
Jeff
Brink
Staff member
mvp
Your welcome Jeff. I'm happy to hear that you got the problem resolved. Thank you for posting back your results.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
