Control Panel Icons
How to Change a Icon in the Control Panel in Vista
This will show you how to change most of the classic view Control Panel icons listed below to whatever you want them to be.
To change the icons back to their default (original) icons, see the post below for a list of the original default paths, and then follow these same steps.
See: Control Panel Icons
The icons you decide to use must be a 256x256 .ico icon file (not .PNG) to be used in Vista without any viewing problems with a larger size. A PNG file must be converted to a 256x256 ICO file before it can be used. To convert a PNG to ICO you must use a program such as this free 30 day trial program called Axialis IconWorkshop: Axialis IconWorkshop Download Page . Here's a good location for some icons: deviantArt: Dock Icons
EXAMPLE: Default Classic Control Panel Icons
OPTION ONE
How to Change the Easy Control Panel Icons
1. Open the Start Menu.​
4. Go to the registry key location (Icon Locations below) in regedit for the icon you want to change.​
Icon Locations:
HKEY_CLASSES_ROOT\CLSID\{add location here from below}​
Control Panel Icon
[/TD]
[TD]
CLSID Location
[/TD][/TR]
[TR][TD]
Add Hardware
[/TD]
[TD]
{7A979262-40CE-46ff-AEEE-7884AC3B6136}\DefaultIcon
[/TD][/TR]
[TR][TD]
Administrative Tools
[/TD]
[TD]
{D20EA4E1-3957-11d2-A40B-OC5020524153}\DefaultIcon
[/TD][/TR]
[TR][TD]
Default Programs
[/TD]
[TD]
{17cd9488-1228-4b2f-88ce-4298e93e0966}\DefaultIcon
[/TD][/TR]
[TR][TD]
Device Manager
[/TD]
[TD]
{74246bfc-4c96-11d0-9bef-0020afgb0b7a}\DefaultIcon
[/TD][/TR]
[TR][TD]
Ease of Access Center
[/TD]
[TD]
{D555645E-D4F8-4c29-A827-D93C859C4F2A}\DefaultIcon
[/TD][/TR]
[TR][TD]
Folder Options
[/TD]
[TD]
{6DFD7C5C-2451-11d3-A299-00C04F8EF6AF}\DefaultIcon
[/TD][/TR]
[TR][TD]
Fonts
[/TD]
[TD]
{D20EA4E1-3957-11d2-A40b-OC5020524152}\DefaultIcon
[/TD][/TR]
[TR][TD]
Network and Sharing Center
[/TD]
[TD]
{8E908FC9-BECC-40f6-915B-F4CAOE70D03D}\DefaultIcon
[/TD][/TR]
[TR][TD]
Parental Controls
[/TD]
[TD]
{96AE8D84-A250-4520-95A5-A46A7E3C548B}\DefaultIcon
[/TD][/TR]
[TR][TD]
Personalization
[/TD]
[TD]
{ED834ED6-485A-4bfe-8F11-A626DCB6A921}\DefaultIcon
[/TD][/TR]
[TR][TD]
Printers
[/TD]
[TD]
{2227A280-3AEA-1069-A2DE-08002B30309D}\DefaultIcon
[/TD][/TR]
[TR][TD]
Programs and Features
[/TD]
[TD]
{7b81be6a-ce2b-4676-a29e-eb907a5126c5}\DefaultIcon
[/TD][/TR]
[TR][TD]
iSCSI Initiator
[/TD]
[TD]
{A304259D-52B8-4526-8B1A-A1D6CECC8243}\DefaultIcon
[/TD][/TR]
[TR][TD]
Sync Center
[/TD]
[TD]
{9C73F5E5-7AE7-4E32-A8E8-8D23B85255BF}\DefaultIcon
[/TD][/TR]
[TR][TD]
System
[/TD]
[TD]
{BB06C0E4-D293-4f75-8A90-CB05B6A77EEE}\DefaultIcon
[/TD][/TR]
[TR][TD]
Taskbar and Start Menu
[/TD]
[TD]
{0DF44EAA-FF21-4412-828E-260A8728E7F1}\DefaultIcon
[/TD][/TR]
[TR][TD]
Welcome Center
[/TD]
[TD]
{CB1B7F8C-C50A-4176-B604-9E24DEE8D4D1}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Anytime Update
[/TD]
[TD]
{BE122A0E-4503-11DA-8BDE-F66BAD1E3F3A}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Cardspace
[/TD]
[TD]
{78CB147A-98EA-4AA6-B0DF-C8681F69341C}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Firewall
[/TD]
[TD]
{4026492F-2F69-46B8-B9BF-5654FC07E423}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Sidebar
[/TD]
[TD]
{37efd44d-ef8d-41b1-940d-96973a50e9eo}\DefaultIcon
[/TD][/TR][/TABLE]
5. In the right pane, right click on (Default) and on Modify. (See example screenshots below)​
Example Original Path:
Example New Path:
6. Type in your new Icon's full file path. (See screenshots below step 7)​
EX: C:\(where ever you saved the icon)
7. Click on OK to apply.​
NOTE: Now look in your Control Panel and you will see the icon has been replaced with the one you added.​
OPTION TWO
How to Change the Harder Control Panel Icons
Icon Locations:
Control Panel Icon
[/TD]
[TD]
CLSID Location
[/TD][/TR]
[TR][TD]
Autoplay
[/TD]
[TD]
{9C60DE1E-E5FC-4of4-A487-460851A8D915}\DefaultIcon
[/TD][/TR]
[TR][TD]
Backup and Restore Center
[/TD]
[TD]
{335a31dd-f04b-4d76-a925-d6b47cf360df}\DefaultIcon
[/TD][/TR]
[TR][TD]
Color Management
[/TD]
[TD]
{B2C761C6-29BC-4f19-9251-E6195265BAF1}\DefaultIcon
[/TD][/TR]
[TR][TD]
Performance Information and Tools
[/TD]
[TD]
{78F3955E-3B90-4184-BD14-5397C15F1EFC}\DefaultIcon
[/TD][/TR]
[TR][TD]
Power Options
[/TD]
[TD]
{025A5937-A6BE-4686-A844-36FE4BEC8B6D}\DefaulIcon
[/TD][/TR]
[TR][TD]
Problem Reports and Solutions
[/TD]
[TD]
{FCFEECAE-EE1B-4849-AE50-685DCF7717EC}\DefaultIcon
[/TD][/TR]
[TR][TD]
Scanners and Cameras
[/TD]
[TD]
{00f2886f-cd64-4fc9-8ec5-30efbcdbe8c3}\DefaultIcon
[/TD][/TR]
[TR][TD]
Speech Recognition
[/TD]
[TD]
{58E3C745-D971-4081-9034-86E34B30836A}\DefaultIcon
[/TD][/TR]
[TR][TD]
User Accounts
[/TD]
[TD]
{60632754-c523-4b62-b45c-4172da012619}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Defender
[/TD]
[TD]
{D8559EB9-20C0-410E-BEDA-7ED416AECC2A}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Sideshow
[/TD]
[TD]
{E95A4861-D57A-4be1-AD0F-35267E261739}\DefaultIcon
[/TD][/TR]
[TR][TD]
Windows Update
[/TD]
[TD]
{36eef7db-88ad-4e81-ad49-0e313f0c35f8}\DefaultIcon
[/TD][/TR][/TABLE]
5. Right click on DefaultIcon (in left pane) and click on Properties. (See screenshot below)​
NOTE: We will have to take ownership of the registry key DefaultIcon (in left pane) to do this.
6. Here's the window to start taking ownership. (See screenshot below) Open another tab or window in IE and go to How to Take Ownership of an Item in Vista and follow instructions for method two step 3.​
7. When you have taken ownership. Right click on (Default) in the right pane and click on Modify. (See screenshot below step 5)​
8. Type in your new icon's full file path and press OK. (See screenshot below)​
NOTE: Your Icon has been changed in Control Panel. If not, then you didn't take ownership of DefaultIcon and you will need to repeat these steps.​
Default Control Panel Icon Paths in Vista
Follow the above posts instructions on how to change the icons and just put the original path location for the data.
BLUE = Easy ones
RED = Harder Have to take Ownership ones
Use Copy and Paste to save yourself time.
[table="head"]Control Panel Icon | Default Icon Path
Add Hardware |%SystemRoot%\System32\hdwwiz.exe,-1501
Administrator Tools| %SystemRoot%\System32\imageres.dll,-114
Default Programs|%SystemRoot%\System32\imageres.dll,-24
Device Manager| %SystemRoot%\System32\devmgr.dll,-201
Ease of Access Center| %SystemRoot%\System32\accessibilitycpl.dll,-1
Folder Options| %SystemRoot%\System32\imageres.dll,-166
Fonts| %SystemRoot%\System32\main.cpl,9
Network and Sharing Center| %SystemRoot%\System32\netcenter.dll,-1
Parental Controls| %SystemRoot%\System32\wpccpl.dll,-1
Personalization| %SystemRoot%\System32\themecpl.dll,-1
Printers| %SystemRoot%\System32\imageres.dll,-26
Programs and Features| %SystemRoot%\System32\imageres.dll,-87
iSCSI Initiator| %SystemRoot%\System32\iscsicpl.exe,-1
Sync Center| %SystemRoot%\System32\synccenter.dll,-1000
System| %SystemRoot%\System32\imageres.dll,-149
Taskbar and Start Menu| %SystemRoot%\System32\imageres.dll,-80
Welcome Center| %SystemRoot%\System32\oobefldr.dll
Windows Anytime Update| %SystemRoot%\System32\windowsanytimeupgradecpl.dll,-1
Windows CardSpace| C:\Windows\System32\icardres.dll,-4096
Windows Firewall| C:\Windows\System32\firewallcontrolpanel.exe,-5004
Windows Sidebar|%ProgramFiles%\Windows Sidebar\sidebar.exe,-100[/table]
AutoPlay| %SystemRoot%\System32\autoplay.dll,-1
Backup and Restore Center| %SystemRoot%\System32\brcpl.dll,-1
Color Management| %SystemRoot%\System32\colorcpl.exe,-5
Performance Information and Tools| %SystemRoot%\System32\perfcentercpl.dll,-1
Power Options| %SystemRoot%\System32\Powercpl.dll,-1
Problem Reports and Solutions| %SystemRoot%\System32\wercon.exe,-1
Scanners and Cameras|%ProgramFiles%\Windows PhotoGallery\ImagingDevices.exe,-102
Speech Recognition| %SystemRoot%\System32\Speech\SpeechUX\Speechuxcpl.dll,-1
User Accounts| %SystemRoot%\System32\usercpl.dll,-1
Windows Defender| %ProgramFiles%\Windows Defender\MsMpRes.dll,-103
Windows Sideshow| %SystemRoot%\System32\AuxiliaryDisplaycpl.dll,-1
Windows Update| %SystemRoot%\System32\wucltux.dll,-1[/table]
Hi brink,
Thanks for this guide :)
I would like to know if it is possible to change the icons of Control Panel(the one in the start menu), Hard Disk & DVD Drives?
Thanks again! :D
niGht kiD,
From the PM you sent me:
It took me a bit to track it down, but I found a way to change a drive icon in the registry. I wrote up a tutorial on it. Here is the link for you.
How to Change a Drive Icon in Vista
Have fun and enjoy,
So only the 32 icons listed below the LOCATION can be changed? How about the others? Like Realtek HD Audio Manager, Game controllers...etc Ahhh... I'm so fussy :o
LOL niGht kiD,
These are just the ones I found so far. I dug for the others, and no luck yet. Hopefully I will find them one day. :p
What if an unidentified icon with no name has appeared in the Control Panel? It looks like a piece of paper with an empty comment balloon superimposed on it. How can I find it's name and location?
Mike
Hi Mberry,
It sounds similar to the Text to Speech icon. Did you install anything before it appeared? See if highlighting it will let you see the name. You can also right click on it and click Create Shortcut for the desktop, then right click on the shortcut (on desktop) and click Properties to see if it will give you a name.
Hi Claustrawberry,
Sorry, I have not found the Mouse icon yet. :(
I like the Mighty Mouse idea though. ;)
Hay Shawn, have you havd any luck in finding how to change the "View 32-bit Control Panel Items" icon? For some strange reason, when I changed the control panel Icon using your tutorial, the one in the start menu didn't change, all the other ones did, including the one on the desktop, just the start menu one and the 32-bit didn't change. Perhaps windows might be using a different registry key indicating the location of the icon. Got any clues where I could find it?
Please reply ASAP
Raashid
    HP Pavilion dv3510nr Entertainment Notebook PC
    Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
    Inventec 1505
    4.00GB
    NVIDIA GeForce 9300M GS
    Generic PnP Monitor
    WDC WD3200BEVT-00ZCT0
    Alps Pointing-device
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with
Hello Rasshid,
Sorry, but I have not had any luck finding those yet. I'll keep looking though. :(
    Inventec 1505
    4.00GB
    Generic PnP Monitor
Rasshid,
Yes, that is a handy little app. :)
yes it sure is handy, and by the way another way you could tryfinding the location of the icons is by going to the control panel in classic view, and right click on the icon you want to change and select create short-cut, when you create the shortcut, right cilck on it and select properties, then try changing the icon and you will be shown the current location of the icon :)
    Inventec 1505
    4.00GB
    Generic PnP Monitor
