Control Panel menus closing right after being opened
AJ001
Posts
7
So when I open the control panel I can only access certain menus. The ones I cant open mainly are User Account Controls, System and Performance Information and Tools. Any ideas on how to fix this problem?
Hello AJ001,
Welcome to Vista Forums!
I would suggest running a virus scan, spyware scan, and malware scan.
This type of problem seems to be comonly associated with those type of infections.
Ben
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
AJ001
Posts
7
Thanks. I ran McAfee and windows defender but neither of them came up with anything... I'm gonna try to get my hands on adAware and scan with that
johngalt
Antidisestablishmentarianist
3rd Rock
Posts
3,944
Is your login (username) an administrator or a regular (standard) user?
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    Cable: 330+ Mbps down / 30+ Mbps up
    Windows 10 Insider Preview (current)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Lenovo
    Lenovo
    Lenovo
    Logitech MX Master | Synaptics TouchPad
    Lenovo
    330+ Mbps downstream | 30+ Mbps upstream
AJ001,
I have read that Macafee isnot the greatest program. If you like it then that is completely your choice. But here is what i suggest.
If you are good with computers(and be honest with yourself), use comodo internet security. I has a built in firewall which blows windows firewall out of the water. Also has a great anti-virus scanner.
If you are not then you should download Avast! home edition. This was my previous AV and it works just as well but there is no firewall and is ment for more basic users(my opinion, no offense to anyone but comodo is much more advances then Avast).
Also, try scans with MalwareBytes and Spybot S+D(all 4 programs can be found in brinks FREE Software Thread
http://www.vistax64.com/software/115872-free-software-list-vista.html
Once again that is what I would do.
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Airbot
Posts
2,010
#9
Hi Aj011,
I would suggest that you schedule a boot time scan with avast. Open avast and in the top left corner click on the settings icon. click on scedule boot time scan. click it and check archived files as well. restart your computer and let it run. WHen it prompts you to take an action for a virus then try to delete it if possible or put in quarantine. You may have only one virus or many as it will prompt you every time it finds something. Just let it run thru and when it's finished it will restart your comp.
It's usually good to have only one major Antivirus program installed on your machine. More than that and you can have conflicting problems. You can have one or more antispyware/adware programs installed as well without any problems. Some good ones are Malwarebytes Anti malware and A Squared Free but there are others, it's your choice. If your problem persists after your scan you can run System File Checker and Checkdisk.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html
Just some simple suggestions :)
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
AJ001
Posts
7
#10
Thanks for the advice. I did run the boot time scan with avast and thats when it came up with the virus and I deleted it, but yet the problem persists. Ill try some the spyware software you mentioned
Thats very weird AJ001,
I will do some google searches on this and see if i cant get anything on it. Ill be back as soon as i get some info
Sorry for the wait,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
#12
Aj,
Do you have SP1 installed?
I have read in a few places that sometimes this update does help.
Let me know
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Airbot
Posts
2,010
#13
DId you try system file checker and checkdisk yet?
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
AJ001
Posts
7
#14
I checked if i had SP1 and I already do, but I'll try to redownload it and see if it fixes the problem or not. I did run system file checker and it said there were errors and it fixed some of them, but the majority could not be repaired. Chkdsk wont run in write mode so it hasn't helped any, thats the main reason I'm trying to get this problem fixed
Hey AJ001,
I have done a ton of research and didnt find much. Trying running WIse Registry Cleaner 3. I know it seems odd but its worth a shot. Maybe there is something unwanted in there that it could pick up. The program is free in brinks list of free software. MAKE SURE YOU BACK UP YOUR REGISTRY FIRST! DO A SYSTEM RESTORE CHECKPOINT ALSO!!!!
Let me know how it goes
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Studley
Posts
1
#16
Greetings,
was there ever a solution to this problem? I have it now. I am Vista Home Premium x64 with SP2. I did have a small issue when I got the computer as it was installed in German. I had to use a tweak to get it into English.
Now I cannot open User Administration (and a few others) and I cannot get Windows Updates to work. Any help and advice is appreciated.
S.
