Convert RJ45 to RJ11
Do you think that would work or we have any such convertors?
From my wireless connection I ppoe cable instead of phone cable, so the end is an RJ45 connector, my router input for wireless is RJ11, so if i convert that RJ45 to RJ11 and connect to the router.. that should be able to project the wireless connection right??
I can't find any RJ45 TO RJ11 convertors??
Thoughts
Cheers
think that won't work .. don't know.. the internet transmitter is wireless. so I have an antenna sitting on the window, connecteed to a none wireless router which got special inputs to receive and convert the radio signal to normal internet signal. Therefore I have a ppoe network cable that comes out which I connect to my computer as a RJ45
But I want to connect that network cable to a wireless router which has an input of RJ11 (PHONE JACK) input for internet. So i need I convertor to convert the RJ45 TO RJ11.
If I do that, the router will generate its own IP address and so there will be a conflict between both routers as both will try to generate an ip address, so if i put the second router which is a Thomson TG585 to have static ip address and convert the router to a repeater, it should be able to project that internet connection signal as wireless??
Who thinks thats possible??
cheers
Ash
Patonb
canada
So yhou have a ppoe modem, attached to a router, and you want to skip the modem?
If yes, can't be done as a router deoesn't know how to speak modem.
Your best option is to chain them. Need to know your modem and router.....
This is all theoretical as I'm not sure were on the same page.
Edit,
Seems we're not...
I'd just buy A basic wireless router, 30 bucks basically.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Yeap the other one is a modem sorry which have a ppoe cable connected to it, that connects to my pc as RJ45.
I need that modem as it converts the radio signal to internet signal.. how do i chain them? i'll see if that applies to my situation..
thanks m8
Patonb
canada
What models are the modem and wireless?
Patonb
canada
#9
Saddly with the THOMSON you can't do what I said. But any wifi enable router will do it.
Guess your best option is to go buy an inexpensive router, and plug it into the wireless modem.
#10
ok, I went and brought a woosh compatible router for that modem.. Now I have like 5 routers sitting at home.. lol.. that one be only a plug and play thingy... thanks guys for putting up with my crazy inventions..
Patonb
canada
#11
While I have cable internet, this is the setup I have too... modem to a wifi router... I have 3 wifi routers in my house.
