Solved convert to dvd
jasond19
Power User
im trying to convert (avi) i think to dvd. when i would burn to dvd, it never would play on dvd, all the programs i tried were realy complex, is there something out there that is shorter?
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor ([email protected]) Mobile Intel(R) 945 Expr
Arvinwebb
Vista Lover
Hello,
If it is an AVI file with no DRM (meaning it has no proprietary "locks" preventing copying or modifying), then Nero 8 and upper version should be able to convert this to standard DVD format and then burn it to a DVD.
You can also use Xilisoft AVI to DVD Converter & Burner. Some Features of this application:
1. Convert AVI to DVD
2
.Create DVD with Menu
3.Multithreading and Multi-Core Processing
...............etc...
Thanks.
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
ilikefree
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
americancritic
Hello Jasond19, very good advice by everyone. As a vista lover mine is a 64 bit and came with Cyberlenk DVD suite Deluxe and Windows DVD maker in the popup list, did they not give you any thing to burn DVD's if so that stinks, have you tried looking here to see if there is anything you can use.
http://www.vistax64.com/software/115872-free-software-list-vista.html
and it is ever growing thanks to Brink and maybe other's take a look..
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
t-4-2
Banned
1. You use Home premium. You have Windows DVD Maker included in the system. Use it to burn items to DVD.
You will be able to play it in any portable DVD player or any computer after you have burned it with Windows DVD Maker.
2. To be on the safe side, because not all avi formats are supported by Windows, google for a FREE video converter.
Use it to convert your avi to WMV format.
Then open Windows DVD Maker > add the WMV to it > start the burn process.
Note : I use Prism Video Cnverter. It is free, and it does the job for me.
tom982
٩(͡๏̯͡๏)۶
What I do is:
Download and install K-Lite Mega Codec Pack:
Free-Codecs.com :: Download K-Lite Mega Codec Pack 7.1.0 : The K-Lite Mega Codec Pack includes the K-Lite Codec Pack Full, QuickTime Alternative, Real Alternative support and Monkey's Audio DirectShow decoder.
This will allow 99% of video and audio formats to be viewed in Windows without the need for extra software which would clog your system up. A codec basically tells Windows how to read the file and this program is a bundle of codecs.
Once you've installed this, you can use Windows DVD Maker to burn pretty much any video file to a disc. This is a lot faster as no conversion is needed!
Hope this helps!
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
t-4-2
Banned
jasond 19,
If you issue has been resolved by one of us, please let us know so that we can have this thread marked as " solved ". That way, others with a similar problem know there is a solution in this thread.
If you obtained a resolution somewhere else, please enlighten us.
Thank you.
jasond19
Power User
i do appogize my issue has been resolved, ty very helpful
    toshiba satellite
derekimo
Moderator
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
jasond19
Power User
yes windows dvd maker worked beautufly, i was making the problm to diffclt, looking to far into it, when the answer was simply in windows, thanks again vista
    toshiba satellite
