coppy and frozen video on my PC
davidmke
I'm wondering if just an upgrade to Windows 7 Home Premium would solve the problem with choppy and frozen video on my PC from video I imported from my new Nikon 3100 digital SLR. Nikon said, "This happens whenever the computer does not have the proper drivers to playback high definition videos". And they said a fast processor and a lot of installed memory- but even that may not be enough because there are "...a lot of factors that determine system performance". Or would it be better to buy a new computer. Thanks, David in Milwaukee
    Dell Inspiron 531s
    1.00 GB
Welcome
I just read your comuter specs and see that you have 1GB Ram. You cannot expect very good perfomance with 1GB of Ram. Most of that is needed just to run Vista. With Home Basic, you are using half your Memory just for the OS.
You may want to test to see if your computer is powerful enough for Seven.
Dont forget, this test will show if you have the minimum requirments and not if your software will run well.
Windows 7 Upgrade Advisor - Download - Microsoft Windows
You should add more memory.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
That's strange. This article- Dell Inspiron 531s Review & Rating | PCMag.com says that it comes with 2 Gb of system memory and it also says it has discrete graphics. Later on, it says that the graphics card wouldn't be available until after Novemeber 1, 2007. So, I don't know what he has.
If he doesn't have 2 Gb of RAM and a discrete video card, he's fighting a real battle with video since the integrated graphics is probably sharing operations (and memory) with the CPU.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
