CorelDraw X6 error
IsaccoMichele
When my client tries to usethe capture feature connecting to "What the Font", he gets thiserror....
Coreldraw error: your computer may not be connected to the internet or you mayhave a firewall installed that is blocking access to the internet
MilesAhead
Eclectician
Welcome to the Forums.
I don't know what port CorelDraw uses. But it very well could be blocked by the firewall. A quick test would be to disable Windows Firewall from the Services applet in Control Panel. If it starts working right away that was the issue. Then you need to find out which port it tries to use. Probably could find out from a forum on the Corel web site.
Make sure the customer enables the firewall after the test so you won't be blamed for any malware. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
