Corrupt HDD - how to reinstall Vista with no discs?
jaidee
Old Acer Aspire 7720Z PC. Vista Home premium SP2.
HDD became corrupted and could not get past the system recovery. Following various tutorials have imaged and used some recovery programs booting with Rufus and generally played around with it but no joy on the overall operating system or Office 2007. Personal files were all backed up elsewhere so not an issue for them. HDD is currently in a USB enclosure.
Looking to potentially upgrade components on the laptop and move to Win 7 but would like to get Vista back and working first. I have the Product part no., Product ID and CD key - but no CD......
If I format the original disc can someone suggest how I could get Vista back on the machine?
Thanks
    Vista
wither 3
You can get a Vista ISO from ex_brit which doesn't have any updates after SP2.
Go to this thread-
In the first post by ex_brit, highlight his forum name and select Start Conversation.
Request the Vista ISO and identify if you need 32 bit or 64 bit.
You might also post your problem in the appropriate section of the forum and get some help with it.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wither 3
Crashes and Debugging. Not sure why none of the other guys are responding to this one.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
jaidee
Thanks to the suggestion from wither 3 and ex_brit providing the ISO and some instructions my laptop is now back up and sort of working.......
I say sort of as I cannot get wi-fi to work but still playing around with it.
Thanks to you both
:thumbsup:
    Vista
wither 3
After you installed, did you run the check for updates? There should be over 200 of them.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wither 3
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
jaidee
Sorry been busy and only just seen your reply.
Yes and no. Left it running for about 4 hours (twice) and other than the Update Agent nothing has appeared.
How long should it take (roughly) and do you think this will solve the wi-fi issue - otherwise I think I may have a hardware problem with it.
    Vista
Vistaar
I would really like to get rid of those annoying pop ups at start up - any ideas?
Uncheck "Always ask before opening this file." The instructions you found should solve the well-known Windows Update issue.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
SIW2
Yes, you need to run those 4 microsoft updates.
In this order
Run these two:
KB3205638
KB4015195
Restart.
Then run these two
KB4015380
KB4012583
You can restart after each if you like, but you need to run them in that order.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
SIW2
I have just successfully updated the vista installation media.
If anybody is interested, I can probably post instructions, and something to d/l and install the correct updates into the wim.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
jaidee
In this order
Run these two:
KB3205638
KB4015195
Restart.
Then run these two
KB4015380
KB4012583
Yes ran those plus the IE9 update. I was told to restart after at least the first 3. That solved a couple of the pop ups.
Still had no wifi plus there were 5 "Other devices" with yellow triangle so in frustration used DriverPack utility. That seems to have fixed the wifi although the original Intel Pro/Wireless 3945AB still has yellow triangle but there is now an Atheros adaptor (not mentioned at all in my original documentation).
Fixed also all but one of the others for which I needed to try another utility and that is now fixed.
Now have left the final pop up (Skyel.exe) which is part of Realtek Audio. I cannot seem to fix that. And yes have tried unchecking the box but still comes up.
    Vista
wither 3
From what I can find, the the two devices still showing a problem are related to WLAN/Wi-Fi and you can download software for both of them. It could be that DriverPack didn't install everything it should. You could also try reinstalling the latest RealTek driver.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
skeezix
Maybe you should check your router setup? Your problem appears to be something to do with the router... just my 2 cents worth...
    Windows Vista SP2 32-bit Home Premium
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
erpster4
you have a really old version of the Realtek high definition audio driver. uninstall it, reboot and download & install the latest version of the realtek audio driver from Realtek's web site, which is more update to date than the one provided by Acer.
    Windows 7 SP1 Ultimate x64
    4Gb (3.24Gb usable to OS)
    Sigmatel/IDT STAC9200
