CPU Cooler
Techymike
not so newbie
Power User
I am not overclocking my i7 but was wondering if anyone knows the best cooler that will fit with a gigabyte EX58UD4P with an i7 and in a Antec 900 case. I have two 3870X2's crossfired and the extra fan on the case side. I am running Rivatuner as the fan control on the ATI cat does not work for the 3870's. It never gets hot but I thought I might want to push it some and see what I can do. Yes, It has the stock Fan for the i7. LOL
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
fadedrs
Lost in my own World
Power User
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Techymike
not so newbie
Power User
Thanks, I looked at them and they look nice.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
stoneys-nutz
Gamerholic
Take a look at the Noctua NH-U12P, i cant fault this cooler, it also has a screw spring loaded base as opposed to those crappy push pins.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Techymike
not so newbie
Power User
That baby looks sweet. It looks like it will fit nicely as well. Thanks. I will read up on it more. The price is right there were I want it to be as well.:sarc:
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
stoneys-nutz
Gamerholic
Just one thing, it is a big cooler , so check it will fit, i have a coolermaster stacker 830 and i had to take out one of my side fans for this bad boy to fit lol.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Tarka Dal
I know nothing!
Hi Techymike
don't want to barge in here but you ought to look at this as it's a bargain...and does the job quieter...
Arctic Cooling
:zip:
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache
    1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
Techymike
not so newbie
Power User
Noctua NH-C12P 120mm SSO CPU Cooler
So far I have found this to be the best for my system requirements but I have not decided completely yet. I am in no rush as I don't overclock and the stock fan is doing just fine. I really appreciate all the help and inputs, this has been a tremendous assistance in my search.
Thermaltake ISGC-400 CPU Cooler
I added this as it has a good (not the best) cooling at a low profile fit design. After reading about it, the reviews all said that it fits great in a mid tower that has side fans.
Thank you!
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
Techymike
not so newbie
Power User
The cooler came in fine. I installed it after looking at the paper directions and deciding the only use full thing was the air flow direction and picture of the cooler. Other then that it made a nice place mat for the work. Turns out there are 4 ways you can mount this and only one of them is correct. As long as you look at the airflow then you will have no problems. It took me about an hour to rip at all down and figure out the direction then clean out the dust bunnies.:o And have it all back working again. It fit reeeeeeeeeeeeeeeeeeeeeeeeally close to the side fan but there is not problem with the fit. The temps dropped to 40-43C from 53-57C. It was worth the time and money! Besides that it looks pretty cool as well.:D
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
stoneys-nutz
Gamerholic
Glad you got it fitted all ok, the drop in temps is quite impressive, you must be very pleased, good job. :)
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
fadedrs
Power User
same glad you got it figured out, and you got your temps down
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Techymike
not so newbie
Power User
OOPS! I forgot to mention which one I bought. LMAO
The Cooler master hyper-N520
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
stoneys-nutz
Gamerholic
Nice. :)
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Techymike
not so newbie
Power User
Decided to play around with some things and now have the CPU cooling down to 31 to 39C degrees at full load after hours of operation.Very rarely hits over 40C.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
Techymike
not so newbie
Power User
I shifted the cooler 90 degrees. Now at idle the CPU, all 4 cores are stable at 32to 34C and when all 4 cores are running at 100% for a few hours the system is never above 60C. I can't explain here why all 4 cores are running at 100% but it does have to do with Blue Ray's. :cool::sa:
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
stoneys-nutz
Gamerholic
I don't think you would do any better with water cooling lol, you must be well pleased.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Techymike
not so newbie
Power User
I think I just got lucky that's all.:geek:
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
