CPU Usage So high!
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Hi Chow2rich,
You can use Resource Manager to see what is using your CPU. This tutorial will show you how to if needed. From there, look under the CPU bar drop down arrow for a list of programs and processes that are currently using the CPU and by what percentage.
http://www.vistax64.com/tutorials/111020-resource-monitor.html
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
40
I had a really weird problem with CPU usage. My usage went up to nearly 100% and their were no programs running. It turned out the battery on my motherboard needed to be replaced. Once I did that the CPU usage went back to normal.
    AMD 945
    Asus M5A99X EVO
    ATI 6770
chow2rich
3
Thanks, but I decided to get rid of Vista. I don't like Windows Vista. Especially it's giving me problems. Like network problems. It's not compatible or something. So I restore my Laptop back to Windows XP Media Center. To me XP is better.
ltwally
System 'ministrator
Vista Pro
323
It all comes down to whatever each person feels most comfortable and productive with. Well, at least in your own home. At work, you use what your boss / IT-department tells you to use. ;)
