Solved Create a Gateway OEM Recovery Disc
gruvin2
I recently purchased a Gateway laptop M-6888U that had no software disc provided. I was told by Bestbuy to simply backup my entire drive. I wish to know is there a way to make a recovery disc that WILL install a fresh copy of vista64 or am I screwed since everyone is trying to cut corners? I know I can make a recovery disc that works IF I have a working installation of my OS. My concern is if the drive gets corrupted and my OS needs to be reinstalled I'm screwed, with my only option being to purchase a new copy of Vista.
Any help is greatly appreciated. Thanks.
Brink
Staff member
mvp
Hello Gruvin, and welcome to Vista Forums.
This link at Gateway will help show you how to create a set of OEM recovery discs to use to restore Vista back to factory defaults with if you are unable to from the hard drive's recovery partition. Just repeat again, and select the other option to create the Vista recovery disc and not just one for the applications and drivers disc. :)
Gateway Support - Create System Recovery Discs for the Applications and Drivers External Media in the Gateway Recovery Center
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
gruvin2
You sir are the greatest. I tried to find this info from the gateway support site and could not. I appreciate your speedy response!
Brink
Staff member
mvp
You're welcome Gruvin. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Does this information still exist since gateway was bought out? When you click on the link, it takes you to a general gateway website.
    gateway mt6821
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
I found the information at the link below, but not at Gateway. :)
https://neosmart.net/wiki/gateway-recovery-disk/
Brink I really appreciate you looking into this so very quickly. I am impressed.
I should have included information about not having a Gateway folder to even have access to that feature. I dont know how cheesy this is, but here is a thread I started today. Actually my first thread ever. Anyway, this is a very wordy post if you have time to read it, then great. If not, I understand. It seems that my hidden partition is gone and anything that has to do with a factory reset is gone. This is a used laptop that was manufactured with Vista Home Premium but now it has Windows 7 Ultimate. If you need more infomation here is a link to the post http://www.vistax64.com/general-discussion/302446-trying-reinstall-vista-iso-create-recovery-parition.html#post1396973
Thanks again
    gateway mt6821
Ztruker
It is so much simpler to do an image backup. Recovery is 30 minutes or less and it puts you right back to where you were when the recovery image was created.
Buy an external USB hard drive.
Download Macrium Reflect Free.
Run Macrium and create a full image backup.
Create the Macrium bootable recovery disc to use if you need to restore the image.
You're done.
You can continue to make additional images as you make significant changes to your system.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
Thanks for your response. Im assuming that I would have to install vista again first and then follow these instructions since it has a trial version of 7 ultimate on it right now? Also will I need to reinstall the drivers since I am trying to do a clean install?
    gateway mt6821
Ztruker
Unfortunately, yes. I don't see any other way unless you are willing to go with a Gateway Recovery DVD or DVD set. If so then check the Gateway web site to see how to order them.
Drivers should not be a problem as the Gateway web site has them.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
I have looked on the gateway website and tried to find the drivers but I could not locate them for the MT6821. Was you able to locate them? Actually their website doesnt recognize that model at all. Im not sure why.
    gateway mt6821
wither 3
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ztruker
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
wither 3
Are the drivers for the 6820 and 6821 the same?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ztruker
Yes, I'm sure they are.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
Are the drivers essential? This laptop I'm referring to is going to be used primarily for email and skype. It will be used very little. It seems to work just fine and I haven't installed any drivers yet.
    gateway mt6821
wither 3
In my opinion, they shouldn't be essential for the two purposes you mentioned. If you ran into video or audio problems, the drivers would be the first thing I would look at.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ztruker
Look in Device Manager. If there are any yellow marks or any of the devices (Display, Network, Sound specifically) are not identified fully then yes, the device drivers are necessary. The computer will run better and be less likely to fail with the correct drivers installed.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
