Solved Creative Fatal1ty Headset (Jacks, not USB) Microphone not working
FruLind
Posts
2
First of all, sorry for my english (I am danish).
I'm trying to help my son, as he has troubles with his new headset.
The headset works fine, he can hear everything perfectly, but the microfone doesn't work. I can see, that he is not the first, who has this problem, but now I have read most of the questions/answers and I still haven't found out, what to do to solve it.
The computer is running on a Vista Home Premium 32-bit.
Hope to hear from someone who can help.
Kind regards
A frustrated mother :cry:
stoneys-nutz
Gamerholic
Wale's
Posts
2,685
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
stoneys-nutz
Gamerholic
Wale's
Posts
2,685
Your very welcome, glad it worked out for you, good luck. :)
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Posts
1
If my pc is turned off and I connect my headset, everything works right.But if I wanna hear some loud music, or it's anoying me etch, I wanna unplug it, but then my speakers doesn't work and I'll have to restart my pc to get my speakers working. It's the same problem when I have my pc turned on and I wanna connect my headset, it doesn't work.
Can anyone help me by sharing their experience in regards to this?
magic sing all-in-one karaoke
Posts
5
hey i know im late but im having the same probblem ! when i try to record it just doesent work ! why ? ive played with the settings all day ! please help man, i dont understand this thread , like i dont see the solution :O
    idk
    idk
    idk
    idk
    idk
    idk
    idk
MrNeeds
PC Geek
Lymm, Cheshire, UK
Posts
1,823
Hi Jude, welcome to the forums.
Can I ask you to right click the sound icon in the bottom right of your screen and select recording devices, now right click on an empty space anywhere in that box and click on show disabled devices, now click on stereo mix and enable, if that solves the problem then we are good to go, if not, then please check that the microphone is being picked up in that same window by talking into the mic and watching for movement in the microphone bar, if it's green then we are good.
If it doesn't respond then can you check that the microphone is properly connected at the earpiece, it's a very narrow gap that the microphone input needs to fit down, it should fit very neatly in that gap, hope this helps
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
MrNeeds
PC Geek
Lymm, Cheshire, UK
Posts
1,823
#9
    16Mb Sky bb
fluksCRO
Posts
2
#10
Hy guys...I also have problems with mic...all about setting that you wrote is allright wiht me...i try un-plug mic from headset and plug in directly in slot for mic(pink one) and then mic work properly...so i rally dont now what is the problem...if you have any advice please help :)
