CSS Blue Screen error + memo problems?
Gruxer
2
Location
Canada
Hi. After i came back from holidays i was trying to run css on my pc. There were some updates required to install. After that i loaded the game and there was the information that the files might be loaded faster or whatever and they asked me to format something... During the format my comp restarted and the blue screen showed up for a couple of seconds. Since that moment sometimes when im trying to play css or just to use comp it happens over. The blue screen appears and the comp is being restarted. I looked up on google and ppl have got similar problem but there is no solution on that problem. I was trying to use many kinds of soft to detect the problem. I runned Memtest 86+ and it showed up around 150 000 errors on my memo... i also used memo diagnostic tool and the errors appeared as well. Additionally when there is a file greater than 2 gig~~ compressed with winrar (winrar files 46 mb each) i can not take it out from compression because there are errors showing up. I know that it is not the defective file because it works on different machine but on mine there are errors. Im thinking that it might be something with my ram im not sure... there is my pc:
intel pentium quad core 2.4/ geforce 9800 GTX/ 4 Gig of ram crucial ballistix tracer dual channel/ and asus mobo
there is the link to the blue screen info and to memtest :
http://img120.imageshack.us/img120/2352/memtestpo8.jpg
http://img168.imageshack.us/img168/3509/bs2gi9.jpg
http://img253.imageshack.us/img253/4660/bsnh3.jpg
i hope You gonna help me Thanks
    Intel Pentium Quad Core 2.4Ghz
    Asus P5E WS Pro
    4 Gb Dual Channel 1066 Mhz DDR2
    Nvidia GeForce 9800 GTX
rtt_77388
Shade Tree Geek
Power User
102
Location
Houston Texas
That would be my first guess. Try running one stick at a time and test your ram out.
    Core Duo 2 E6700
    ASUS P5W DH Deluxe
    4g-Corsair XMS2 6400
    ATI 4870x2
    2 Maxtor Essential SATA2 drives Raid 0
    Pioneer 212D SATA DVD-R/W
Gruxer
2
Location
Canada
You were absolutelly right i had my comp on the warranty and i sent it back to the store where i bought from my comp. they said that one stick of ram is busted... i hope it will fix everything when i ll get my comp back again. Thx for reply :)
    Asus P5E WS Pro
