Curious Access Denied problem with vista
Destillat
Quick back story:
I have a Gateway FX, and recently I had to restore my laptop back to factory settings. Well when I did this I made a backup of my entire C:\ drive.
Well that's great and all, because I still have everything, but that's also a bad thing becuase I have EVERYTHING. Including a second windows folder now.
The problem is that when I tried to deleting this I get access denied. Safe mode won't work, changing permissions won't work, I even gave myself ownership in Properties>Security>Advanced>Owner. Nothing.
I saw a thread earlier that said to run command prompt as administrator and enter a series of commands to give myself access but it told me it couldn't find the folder. I'm fresh out of ideas and so now, I turn to you.
Any help is greatly appreciated!
Thanks!
-Alex
garysgold
Hello Alex,
Welcome to the forums.
You can do this through the built in Admin Acct. Info here if needed. http://www.vistax64.com/tutorials/67567-administrator-account.html?filter[11]=User%20Accounts
As stated in the tutorial, it is unwise to use this acct. as a normal user acct. I recommend deactivating it when you have finished deleting the folder.
Hope this helps.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
Destillat
Thanks a lot! I'll edit this post with the results.
Edit: Nothing! This things impenetrable. At this point I don't know what I can do to delete it other than wipe the drive again which I REALLY don't want to do. But I'm also not keen on keeping 20 gigs of space occupied for nothing.
Even tried it in safe mode. Any more ideas?
garysgold
Your welcome. Good Luck.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
Destillat
Well I did it but in a rather roundabout way.
It turns out when I set myself to have full control permissions, it didn't apply to the subfolders, no matter what I told it to apply to. So I was faced with living with it or setting the permissions for EVERY SUB FOLDER. I found the solution in the security>advanced menu however. There's a check box that lets you apply the permissions to all inheriting objects within the folder. So that worked. Hurrah!
Thanks again for your help.
garysgold
Glad you got it sorted out.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
