Cyberlink 7 Ultra amd Vista.
Techymike
not so newbie
Power User
212
Location
CA due to work but miss Texas!
I figure that some are having the same problems I ran into and now have fixed. With Xp there was no problem but when I loaded Vista the program went crazy. First no BD's would play at all. After getting this to work I found some BD (blue ray) movies played fine while others did not. The Audio went from DTS to 2 channel. There is a patch for fixing the some play and some don't. If I get an OK from a Mod I will post the downloads to make it easier. These are downloads from the Cyberlink's download site.
First is : CyberLink.4617_TaRe38_DVD080917-02_Normal
Second is : CyberLink.3613(EVR)_DVD071211-02
In that order. The very first thing I did was to uninstall and then reinstall the program Ultra 7 version 7.1 whcih then upgraded to version 7.3. I am useing the LG GGC-H20L Blue Ray DVD ROM which needed this LG-ODD.4407_HLDS_DVD080926-03
Now everything works perfectly. I hope this is some help for some.
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
