Solved Data Execution Prevention
scsiefker
I am have an awful time with DEP not allowing me access to several sites and downloads. I get the DEP is shuting down Internet Explorer. I have tried everything. I've been on Window's website looking for answers...nothing helps. I would love to banish DEP from my computer!! Anyone with the same problem??? My computer is only a few months old runs on Vista 64 bit and is shuting down on items I have logged onto forever! I am furious!!!
Brink
Staff member
mvp
Hello Scsiefker, and welcome to Vista Forums.
You might try resetting IE first to see if it may just be a add-on causing this.
Since you are running a 64-bit system, you will most likely have a No execute option in the BIOS settings for the CPU DEP feature if supported. However, just remember DEP is to protect your system from not allowing a program to execute in restricted memory. If some program is tripping DEP, then do you really trust it and want to use it?
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
Could be something from the websites that are doing this trying to load in the restricted memory tripping DEP.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
scsiefker
I tried resetting IE and the DEP did finally go away. What would cause that to happen in the first place? Is there any way to prevent it from happening again?
Brink
Staff member
mvp
It may have been some add-on or activeX item that you may not have known was on there.
I'm happy to hear that it is gone now. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
